Help! Best swing arm replacement for kz1000
- iosteyee
23 Oct 2008 04:28
I've read through the threads and can't get a true sense of what swing arm best replaces the original kz1000 swing arm.Does the GS1100 bolt right on, does the GS1000 also fit. Do they bolt right up? Is one , or the other the same length as stock? Can anyone inform me of the specific year/type of arm, the mods needed to complete the job ect. I'm not interested in lengthening the swing arm, just stiffening it. Thanks very much.
Ian
Ian
- StreetfighterKz
Re: Help! Best swing arm replacement for kz1000
23 Oct 2008 04:48
If you're only interested in stiffening the arm just brace the stock one. That way you know it fits without mods. If you want to go with a wider tire then teh Gs1100E arm would be the best thing as I believe the arm is close to the same length as the Kz arm.
DutchZ braced his swingarm. Myabe he can chime in here on how he did it. For the full build thread click here .
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- galaxian
23 Oct 2008 06:06
The aluminum GS swingarm bolts right in. No mods except a washers to take up the slight gap. The only change is you will need suzuki or older honda shocks with a clevis at one end instead of the eye.
ZRX1100/1200 swingarms bolt right in but you will need to modify the foot controls since the bolts are in the way of the bracing. If you run rearsets you will be ok.
Any swingarm can be made to fit, its just time and money really.
1977 KZ1000A1, 1979 KZ650 C3
- rstnick
23 Oct 2008 06:16
I also had a brace added to a stock arm, thus keeping the stock length and not needing to buy a new chain, wheel, brakes/lines and whatever else may be needed when a longer arm is put on. The center stand mounts did need to be removed though.
The GS aluminum arms are longer than stock are they not?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- iosteyee
23 Oct 2008 07:18
I have the '77 swing arm with only two bearings, not the latter four bearing model. Is it worth getting a four bearing model to brace, or is the two bearing one good enough?
- racer54
23 Oct 2008 12:02
The GS swingarm is about 1 1/2" longer than a KZ arm.
- PLUMMEN
23 Oct 2008 12:38
i like the looks of the braced stock arms,but it adds a lot of unsprung weight to an allready heavy swingarm
23 Oct 2008 14:04
don't think you can notice a difference between two or four bearing except when it comes time to change em.
- saxjonz
- KawboyZ
23 Oct 2008 19:41
Ok what about the zr1100 swing arm? How would that work with a kz or would it not? I had an old zep11 that burned in a garage fire but couldn't salvage the parts of it before my next door neighbor complained about trash in my back yard. My garage was a cinder and she was worried bout a little old bike. But I was thinking that the swing arm woulda looked nice on my bike.
79 LTD B3
