KZ 650-C3 Custom Vs. KZ650-D2 SR
  • Oldwolf
  • Oldwolf's Avatar Topic Author
20 Oct 2008 20:47
#242928
Looking to put Dual disc on my 77 KZ1000-A1. Looks like the 77 LTD1000 Calipers have the same Part # as the 79 KZ650 Custom and LTD 1000 Calipers. I'm guessing these would be a direct fit, is this correct? But the 79 KZ650 SR Calipers have a different Part #, Whats the difference and would these be a direct fit to my 77 KZ1000.
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: KZ 650-C3 Custom Vs. KZ650-D2 SR
21 Oct 2008 05:58 - 21 Oct 2008 05:59
#242993
I'm not positive, but it could be the mounts are different.
I remember when John was looking for forks for his '80 650.
Seems the lower fork legs were different over the years for the 650. The caliper mounts are at different heights on the forks, so maybe the calipers are a different shape in the mounting area as well.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 21 Oct 2008 05:59 by rstnick.
  • steell
  • steell's Avatar
21 Oct 2008 19:40
#243148
I believe the reason the caliper mounts on the fork lowers are at different heights is because the diameter of the brake rotor varied on different models and different years.
  • Bluemeanie
  • Bluemeanie's Avatar
23 Oct 2008 06:10 - 23 Oct 2008 06:12
#243358
Yup, The fleabay forks I got were designed for dual "smaller" rotors as opposed to my single larger rotor. Caliper mounting points were about 1/4 inch lower. Kawasaki.com is a huge help in situations like this...;)
Last edit: 23 Oct 2008 06:12 by Bluemeanie.
