Need a custom front axle
  • franknsr
  • franknsr's Avatar Topic Author
19 Oct 2008 13:05
#242664
Hey guys-
I've got an 82 650 CSR with 79 750 front forks. The front wheel was mounted by using the 750 axle and machining it down to fit the smaller 650 bearings but I never liked the way the axle sat between the end caps, its to short. Long story short; I need to have an axle made up for this beast. Anyone here capable of the task or have someone they can recomend?
Thanks
Frank
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
Re: Need a custom front axle
19 Oct 2008 16:02
#242693
try 531blackbanshee B)
  • franknsr
20 Oct 2008 02:31
#242778
Thanks, will do.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
  • Makarth
  • Makarth's Avatar
20 Oct 2008 06:35
#242792
can you make a scetch with the dimensions? What material you looking to use. I can't make any promises but if it's all lathe work it might be something I can do here at school
1977 kz1000 - Megasquirt project @ 40% wiring, plenum, and exhaust<--(done!)
  • 77_650B1
  • 77_650B1's Avatar
20 Oct 2008 07:22
#242801
I can do this, got some 4140 laying around which would be a good match. I wonder if your wheel is the same as mine, I've got a wheel from a 77 650CSR. If so you could just give me the dimms of the end caps and I could go to work.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • franknsr
21 Oct 2008 19:12
#243135
Hey thanks for your willingness to help guys. 531 is looking into it for me and he's pretty sure he can fix me up. Just waiting for the replacement part to show up I just got off fleabay.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
