Early Z1 # 3795 right front frame brace crack
  • mtkawboy
  • mtkawboy's Avatar Topic Author
19 Oct 2008 09:11
#242614
I have a 73 Z1, frame serial #3795 that has a hairline crack in the right side frame brace from the steering neck to the front down tube. The bike rides fine and the crack doesnt go all the way to the frame, its just in the brace, is this going to be a problem. I read somewhere that the very early ones did this but dont know if its true or not. Any advise on this would really be helpful.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: Early Z1 # 3795 right front frame brace crack
19 Oct 2008 09:28
#242616
It's a problem with all the 900's and early 1000's.
It's caused by wheelies - and the bike coming down hard on the front-end. Many of these bikes have this problem. Most times it's not a big deal, but in some cases the steering head is tweaked a little.
It's something that should be repaired if you're doing any restoration, but if you ride sanely, it won't be an issue.
  • PLUMMEN
  • PLUMMEN's Avatar
19 Oct 2008 09:32
#242618
guilty as charged your honor!:laugh: my z1 has same issue from my younger days ,im welding mine up and adding extra beefing on the inside of the gusset on both sides where its not so noticable;)
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
21 Oct 2008 13:46
#243064
Well this has me pondering, im gonna go check mz z1 for stress cracks. Maby i shouldnt wheelie it anymore......well ok maby i will every once and awhile. but thats it i promise.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • 77_650B1
  • 77_650B1's Avatar
21 Oct 2008 13:49
#243065
Can you wheelie your 650 very easily oldkaws? I had my front wheel up like 2" one time, but nothing major.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • Mark Wing
  • Mark Wing's Avatar
21 Oct 2008 16:54
#243103
I got a reckless driving ticket once, all it said was "100 yard wheelie" on my 650. I was in a parking lot so it was thorn out.
Mark
Yorba Linda Cal.
  • 77_650B1
  • 77_650B1's Avatar
21 Oct 2008 17:08
#243112
You must have to sit on back and pop the clutch.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • oldkaws4ever
21 Oct 2008 23:22
#243170
ya i can wheelie my 650 very easly. But it's not exactly stock y aknow, its got a 710 kit in the motor, z1 900 carbs, a bigger rear sprocket and smaller front sprocket. Mark i was close to getting a reckless driving ticket, bout a year ago i was on the 900, when the light turned green i stood the front end up and procceded to wheelie till somewere round 2nd gear when i hear the popo sirens behind me. Turns out it was an umarked piggy, but he grew up on kz's so he let me off with a warning.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
