frame bracing?
- jordan
frame bracing?
18 Oct 2008 22:18
I see that kosman sells a frame bracing kit fo the z1, will this also work for a kz1000? I know that the z1 frames were much weaker or flexible than the kz's but should i still get the frame bracing kit for a 1000? I plan on making quite a bit of power, and will hit up the track once and a while. Oh ya, BTW the frame is a 79 1000.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- timebomb33
Re: frame bracing?
18 Oct 2008 22:28
yes as far as i know that frame kit is the same i'd problaly buy the engine mount kit at the same time it helps stiffen things up as well. kosman racing are the kings of speed not the kings of bling they have been around for a long time and know there business well.
I THINK MY POWERBAND BROKE
- FastKaw1
Re: frame bracing?
19 Oct 2008 04:00
What timebomb said.
You can make a bracing kit for haff the price. The two most important parts
are the the plates that get welded it the frame neck. There just triangle shaped
plats 1/8" stock. And the rear upper motor mount.
If you are going with a big tire you will need a out board bearing mount on your
primary sprocket.
XENU
primary sprocket.
XENU
