Which 15T front sprocket?
- bountyhunter
18 Oct 2008 12:56 - 18 Oct 2008 12:59
I wanted to down gear my 1979 KZ 750 a bit by going from a 16T front to a 15T. Z1 has a bunch of 15T sprockets. Is there any special requirement or do all the 530 chain 15T sprockets fit?
EDIT: having done more research, it appears the JTF513 is the one that fits the 750 twins?
Last edit: 18 Oct 2008 12:59 by bountyhunter.
- timebomb33
Re: Which 15T front sprocket?
18 Oct 2008 19:02
you are correct they use the same spline on the out-put shaft just make sure to use the lock tab on the washer and clean the threads really well and red loctite the nut on and you should be fine.
I THINK MY POWERBAND BROKE
- PLUMMEN
18 Oct 2008 19:55
dont forget a chain and rear sprocket
- timebomb33
18 Oct 2008 20:45
looks like i forgot the most important thing -payback for out bidding you on that cal-fab swingarm right.
- PLUMMEN
18 Oct 2008 22:44
thats alright ive already got one someplace i bought in early 80s that i want to make copies of!:laugh:
- timebomb33
18 Oct 2008 23:07
when you get some of them made up let me know and i'll get 1 or 2 from you im planning to build a vintage superbike for geezer road racing. i've got the engine pieces and the frame im going to use i just need forks and swingarm,i know another project. i never could focus. i found out i had a.d.d 25 years too late.
- PLUMMEN
18 Oct 2008 23:10
ive got S.A.D.D serious ADD !mine is 2 over with airtank,just need to find the box :blush:
