Frames 79/80 LTD vs A
  • supercharged
  • supercharged's Avatar Topic Author
18 Oct 2008 00:07 - 18 Oct 2008 00:08
#242375
I have search for a definitive answer, and as of yet, have not found one.
Looking to determine the differences in frames between the LTD and standard KZ1000 around the years 1979 and 1980.
I have heard of some rear peg mounts that might be different, but what about geometry? Didn't the A models have larger rear wheels... which would change the geometry if all else is the same?
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
Last edit: 18 Oct 2008 00:08 by supercharged.
  • Vter Bob
  • Vter Bob's Avatar
Re: Frames 79/80 LTD vs A
18 Oct 2008 06:19 - 18 Oct 2008 06:20
#242389
I'm not a motorcycle expert (and I've never played one on TV) but I know for sure the LTD frames and the standard frames are different. The LTD frames have more rake to give them that "chopper" look. The rear clip of the frames are different also. You are correct that wheel sizes are different also. LTD's using a 16" rear wheel and a 19" front.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
Last edit: 18 Oct 2008 06:20 by Vter Bob.
  • Vter Bob
  • Vter Bob's Avatar
18 Oct 2008 06:22
#242390
Standard frame (both 1980)
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
  • mtkawboy
  • mtkawboy's Avatar
18 Oct 2008 06:32
#242392
Ive converted my 80 LTD completely over to a normal KZ1000,tank, side panels, wire wheels seat and all. All I can say is it rides just fine. If theres a difference, I cant feel it and I have 2 other KZ1000's. I was just never big on the LTD look myself but whatever floats your boat.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
18 Oct 2008 07:05
#242401
As was pointed out by VterBob, there is actually very little difference between the A and B models with respect to geometry. I looked at Mother Kaw's specs for the KZ1000A4 and KZ1000B4 and found this:
KZ1000A4 steering angle: 41 (in degrees)
KZ1000B4 steering angle: 41 (in degrees)
KZ1000A4 caster: 26 (in degrees)
KZ1000B4 caster: 26 (in degrees)
KZ1000A4 trail: 87mm
KZ1000B4 trail: 90mm
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • PLUMMEN
  • PLUMMEN's Avatar
18 Oct 2008 10:18
#242426
so the differance is in the triple trees?
