Honing master cylinder for rebuild
- mtkawboy
17 Oct 2008 17:21
What do you guys use to hone the trianglar squared off cornered master cylinder before installing a rebuild kit ? I dont know of any hone that small so I was thinking of some sandpaper on a stick or something like that
- littlemanonbigbike
Re: Honing master cylinder for rebuild
17 Oct 2008 17:33
I used a 5/16 bolt with the head sawed off and took a hack saw and cut a split in one end the and slid a piece of emory cloth into it and stuck it into the end of a cordless drill. Worked well for me
1982 1100 Spectre
Various other toys
Various other toys
- SPARKY47
- 1980 KZ500 B2
17 Oct 2008 17:50
I've got a new piston assembly for a 5/8 m/c.
Pleeeeeease, don't tell me I've got to hone the damm thing as well?:ohmy:
1980 KZ500 B2
- Jeff.Saunders
17 Oct 2008 18:59
I use a master cylinder hone (they come in just about every size you could conceive) - but before I got that, I used a piece of scotchbrite pad gently threading in and out to get a light crosshatch.
- SPARKY47
- 1980 KZ500 B2
17 Oct 2008 19:01 - 17 Oct 2008 19:11
crosshatch?
Then I have the wrong part:huh:
The bloody thing in front of me has THE MOST delicate lip imaginable.I'd have thought the bore should need to be mirror smooth to achieve a seal?:huh:
No picture I'm afraid,Son in Law,at my request, turned the flash off.
Now it records video:angry: :laugh:
1980 KZ500 B2
Last edit: 17 Oct 2008 19:11 by SPARKY47.
- fixer5000
18 Oct 2008 01:54
i have used the scotchbrite in the past too with good results...use the green its nice and fine ...steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- mtkawboy
18 Oct 2008 06:36
You want a light honed look, not shiny. Do not use mineral spirits, use brake fluid to hone and alcohol to clean it out. Then coat the rubber seals with brake fluid and reassymble. The scoth brite sounds good to me, even have some in stock, thanks guys
- SPARKY47
- 1980 KZ500 B2
18 Oct 2008 07:26 - 18 Oct 2008 07:31
mtkawboy wrote:
Thanks for that,this has surprised me as I'd assumed a mirror finish is required.
I have to ask though, wouldn't the "hilltops" of the hone "drag" and eventually tear the lip? Intuitively, it would seem to be the case.:blink:
Wish I'd studied hydraulics now:)
Also,wouldn't the channels created by honing provide a path for fluid to leak past the lip?
Just a thought,interested to hear opinions.
1980 KZ500 B2
Last edit: 18 Oct 2008 07:31 by SPARKY47. Reason: I'm Old.
- Sleepy
18 Oct 2008 08:29
The small grooves cut when honing allow a VERY thin trace of fluid to help lubricate the seals.
It's the same with engine piston rings - the bore is not smooth
kz650 gs750 cb750
- SPARKY47
- 1980 KZ500 B2
18 Oct 2008 08:35
Sleepy wrote:
Thanks Sleepy,that explains it:)
God,the info on this site is priceless.
1980 KZ500 B2
