Air forks vs standard forks
- Exitpupil
15 Oct 2008 19:35
What internal differences do the air forks have over the standard forks?
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- madderkaw
Re: Air forks vs standard forks
16 Oct 2008 03:58
I bought a set of air forks from a 750 LTD to put on my 650. The problem I found was that the air forks used the smaller size brake rotors. I have a set of the small ones, but I had just went through the trouble of adding a second (large size) disc and having it drilled to match the single disc that came on my 650 LTD, so I put the fork switching project on hold for now. The smaller double setup would probably be an advantage as far as unsprung weight goes, so I still might do it, but then I would have to get the small discs drilled to match. I don't think the small discs would be a problem with braking, because there will be two rotors and I have SS brake lines.
- BSKZ650
16 Oct 2008 05:36
the only differnce I know of is the caps on top,, they have a air fitting on them,,just dont over pressure them
77 ltd1000, current rider
76 kz900, just waiting
- Exitpupil
16 Oct 2008 06:55
I did not know if there were different seals and different shock valving? What is the purpose of the air pressure?
- RonKZ650
16 Oct 2008 07:24
The air is just like an adjustable spring. More air acts like more spring. No use to it really if you have the correct spring in to begin with. The air always leaks out over time. Pain in the azz.
- H1Vindicator
Last edit: 20 Feb 2013 18:56 by H1Vindicator.
