Removing pads
  • Pwallace30
  • Pwallace30's Avatar Topic Author
Removing pads
12 Oct 2008 19:31
#241504
I just pulled the front brakes off of my 650, and accidently pulled the brake lever causing the pads to close. Now I need to re-open them, how do I do this? thanks
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Removing pads
12 Oct 2008 19:55
#241507
Big C-clamp.
1977 KZ1000 A-1
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Removing pads
12 Oct 2008 20:01
#241508
put a piece of rubber hose on the bleeder valve of each caliper and open the valve letting it drain into an old can or whatever you have as you push pistons back into caliper,just remember to top off master cylinder.if fluid looks nasty might be a good time to flush old fluid and bleed brakes.;)
  • timebomb33
  • timebomb33's Avatar
Re: Removing pads
12 Oct 2008 20:06
#241511
stick a large flat screwdriver or small pry bar in between the pads and turn it sideways that will force the brake fluid back up into the master cylinder not a big deal it happens all the time, easy fix.
I THINK MY POWERBAND BROKE
  • timebomb33
Re: Removing pads
12 Oct 2008 20:09
#241512
one other thing if your dealing with dual discs when you get the one side freed up put something in between the pads to prevent them closing up when you free up the other side
  • bountyhunter
  • bountyhunter's Avatar
Re: Removing pads
12 Oct 2008 21:24
#241522
I pry them apart with a wooden stick like a paint stir stick.
  • Pwallace30
Re: Removing pads
13 Oct 2008 06:59
#241553
Thanks for your help again guys, I got them seperated.
  • coppertales
  • coppertales's Avatar
Re: Removing pads
13 Oct 2008 13:43
#241622
Auto parts stores have a nifty tool for resetting caliper pistons.......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
