engine swap on 82 gpz
- ericvm
01 Oct 2008 15:22
does anyone know if the 1983 gpz engine will drop right into the 1982 gpz frame?
\'82 Gpz 750 (KZ 750 R)
- PLUMMEN
Re: engine swap on 82 gpz
01 Oct 2008 15:24
should be a reasonably easy swap since theyre both j motors
- kano
- Not Another Bloody Limey!
01 Oct 2008 16:01
not sure if this is right but.
gpz1100b1 82 injectors go in to head if you use carbs blank off plates will be needed.
gpz1100b2 83 injectors went in through inlet rubbers.
correct me if im wrong.
- steell
01 Oct 2008 16:52 - 01 Oct 2008 16:52
ericvm wrote:
Hmm, kinda funny that most people here assume you're talking 1000/1100 motor on everything.
So are you talking about the 82 GPz750 in your sig? If yes, then yes the 83 motor is an easy bolt in, we stuck a 83 GPz750 motor in a 79 KZ650SR and it was easy.
Last edit: 01 Oct 2008 16:52 by steell.
- ericvm
01 Oct 2008 20:40
oops. yes, I meant the gpz 750. Thanks Steel.
- PLUMMEN
01 Oct 2008 21:27
oopsies!:laugh:
