Removing front brake switch
- ggenovez
28 Sep 2008 17:36
Hi all,
I have a 81 kz1100a1 and the front master brake is leaking.
How do you remove the electrical switch? I figured since I'm rebuilding the cylinder, I might as well paint it.
KZ-1100 A1
- Sandy
- Fly High,Tony
Re: Removing front brake switch
28 Sep 2008 20:32
Isn't it just a small screw that hold the micro-switch in place?:huh:
1977 KZ1000 A-1
- ggenovez
28 Sep 2008 20:42
There was a small clip that holds the outside of the rubber cover, but I did not see the screw.
Where is that located?
KZ-1100 A1
- Sandy
- Fly High,Tony
28 Sep 2008 20:55
Is there not a very small screw on the switch?
I'm not familiar with that set-up,but most of those switches ARE just held in place with a screw...look close.:huh:
1977 KZ1000 A-1
- ggenovez
28 Sep 2008 21:05
Sorry I don't see the screw.
It actually looks like it's pressed in and the lever keeps it in place. The clip holds the rubber boot.
According to the book I'm supposed to "push up on the front brake light switch locking tab and pull the switch free from the lever bracket"
KZ-1100 A1
- MFolks
28 Sep 2008 21:31
If you remove the brake lever there is a plastic piece you rotate and the piston should be able to be removed. I suspect the seals are worn and pressure can't be maintained.
www.z1enterprises.co should have front master cylinder rebuild kits or know where to get them.
- ggenovez
28 Sep 2008 21:46
Thx Mfolks.
I have the piston out already.
My problem is getting the switch that activates when you pull on the lever out.
KZ-1100 A1
- ggenovez
29 Sep 2008 11:42 - 29 Sep 2008 11:43
Perhaps a picture is better than my description...
webservices.motorsportdealers.com/parts/...S/3/07/0065/E-14.Gif
Item 27010
Item 27010
KZ-1100 A1
Last edit: 29 Sep 2008 11:43 by ggenovez.
- ronjones
29 Sep 2008 13:06
I think I know what's going on. On mine the brake switch is "pressed" in using 2 plastic tines on the switch that engages 2 square holes on the housing. You might need to clean it up a bit, to find it, but just use a small screwdriver or something similar to push the tine out of the hole and the switch should just pull out. You may have to push both tines, but I've never had to do that.
- ggenovez
29 Sep 2008 13:18
Thanks Ron,
It sounds like it's similar to the setup for the master cylinder plunger.
I'll have a look at it tonight.
KZ-1100 A1
- ggenovez
29 Sep 2008 18:19
Hey Ron,
just wanted to say thanks. That was it.
The microswitch has a tab that you push in and it pulls out.
Thanks again.
G
Thanks again.
G
KZ-1100 A1
- ronjones
29 Sep 2008 18:55
