steering dampner mount holes on 76
- trianglelaguna
26 Sep 2008 09:09
i was wondering if anyone knows how my steering stabilizer hooks to my lower triple clamps???? i have a tab on the left outside of my frames downtube above and between where the header pipes exit the engine(old reflector mount tab?)and i thought i had a threaded hole in the triple tree lower on top between the fork tube and the brake sensor on that flatish area but know that i've got a stabilzer and want to mount it...icannofindit????do i need to buy a custum clip to grab on the fork tube...thanks craig:silly:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Jack
Re: steering dampner mount holes on 76
26 Sep 2008 12:48
If you are going to use the reflector tab, make sure to get it welded & reinforced or your steering dampener will be dampening air..btdt.
Some dampeners come with a clamp to the forks or you can drill a hole in the lower tree to bolt the rod end of the dampener. 73-75 Z1's had a hole in the tree as did H1/2's.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
