wire wheels
- judgie
wire wheels
24 Sep 2008 09:56
my 650c1 has the cast mag wheels twin disc. can i swap them out for spoked wheels with out changing anything but the wheels? thinking i can swap the rims for some slightly wider alloy ones poss 18"front and rear or both 17".
cheers rob
cheers rob
forever tweeking aircooled engines, well it is my job
77 z650c1
77 z650c1
- judgie
Re: wire wheels
26 Sep 2008 00:26
42 views and no replys?
need to know if the early spoke wheels will fit in place of the mag wheels i have fitted?
cheers rob
cheers rob
77 z650c1
77 z650c1
- Bad Kaw
- Flying Squirell
Re: wire wheels
26 Sep 2008 21:16
If you can find somebody who can tell you if there is a stock-wheel swap, past that point you should be able to just call a rim manufacturer like Excel and see if they can make you some rims then get the right spokes (perhaps another 'issue') and you might be able to have a relatively stock-ish set-up.
-KR
PS> I have NO idea about spoke::mag swaps...but you're at the right place and the weekend is upon us. Somebody will come to the rescue. Perhaps "rstnick". This will be an interesting build you have.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- PLUMMEN
Re: wire wheels
26 Sep 2008 23:04
yes they can be swapped as long as you keep same style brakes,happy now?:laugh:
- galaxian
Re: wire wheels
27 Sep 2008 07:30
IF you can find early kz wire wheels and have them relaced to aluminum rims or any width you'de like and you could go with 17 or 18. I would do 18 all around if given the choice.
1977 KZ1000A1, 1979 KZ650 C3
- judgie
Re: wire wheels
29 Sep 2008 00:53
seen a few sets of wire wheels go on uk e-bay this last month or so. there out there and i'll find a set over the winter and have them relaced with some 18" rims.
thanks for the answers
cheers rob
cheers rob
77 z650c1
77 z650c1
