Looks like my chain took a sh*t...
  • RonKZ650
  • RonKZ650's Avatar
Re: Looks like my chain took a sh*t...
27 Sep 2008 21:04
#239007
Chains can wear fast if using crap chain oil like PJ1, don't use it. Like I've said before I get 30,000 miles out of a chain at a minimum and got 60,000 out of the last. Yes some orings threw off, I got another 30,000 miles after this happened. Probably most readily available chain lube is in the same boat as PJ1 meaning it's complete crap, meant to minimize cleanup. Minimizing cleanup=no lube, so throw away the chain after 6000 miles, bad enough, but 98% of guys don't lube at all which is even worse (marginally than PJ1 but still worse). Worth it?
  • BeeSting
  • BeeSting's Avatar Topic Author
  • Drive it like your tax dollars already paid for it
28 Sep 2008 11:16
#239080
I just got the cover open and it appears as if the large nut for the front sprocket is loose. Is that normal??? There is a some kind of lock washer that is bent to keep the nut from turning much, but there is still play. Is it supposed to be tight?
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)暗闇の女
1980 Honda CX500C - GONE
Christine
  • Old Man Rock
  • Old Man Rock's Avatar
28 Sep 2008 13:58
#239100
"I just got the cover open and it appears as if the large nut for the front sprocket is loose. Is that normal??? "
In case you're not joking....
By no means is this to be loose... On the KZ900, it's torqued at ~ 87 - 108 ft lbs.... Once torqued, the tabbed washer is to be bent on the bolt flat side to insure it doesn't come loose....
This counter sprocket nut coming extremely loose or backing off could one cause severe injury during a ride (death). Two could cause sever lower end damages (output, drive, clutch and crank shafts/gears. Basically stating, NOT a good thing to happen...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • BeeSting
29 Sep 2008 10:23
#239221
yeah, I wasnt joking... well damn
I think I need to start selling "borrowed time" on craigslist
BeeSting
Christine
  • BeeSting
29 Sep 2008 10:29
#239223
If there's no visible damage to the countershaft sprocket is there a flatness spec I should be looking for to determine if it should be replaced? or replace it anyways?
BeeSting
Christine
