swing arm bush/bearing
- judgie
23 Sep 2008 01:26
have a 77 Z650C1. have side to side movement in the swingarm so am going to order some bushings/bearings. what i need to know is has it got bushings or bearings? dont want to have to strip it to find out as its my daily ride and down time is not a option.
looked in two differant manuals and online at parts shops and cant work out when they changed to bearings.
cheers rob
cheers rob
forever tweeking aircooled engines, well it is my job
77 z650c1
77 z650c1
- RonKZ650
Re: swing arm bush/bearing
23 Sep 2008 07:41
Yes the 77 uses those bushings. I'm not sure if you're the same member that asked this a week or so ago, but just in case you don't know, there's a center grooved tube running in those bushings. The grooves run up to the zerk fitting. Kawasaki idea was grease in the zerk would flow down the grooves in the tube and lube the bushings. This did not work because the grease would harden and clog the grooves. No lube meant the tube would begin to rust and wear the bushings. When you replace the bushings you're going to need to either replace the tube or do a lot of work with emory cloth smoothing out the rust on the tube, because the old rusty tube will not slide into the new bushings.
- judgie
23 Sep 2008 09:12
was not me who asked before and read that post about the tube, will oorder one at the same time.
cheers rob
cheers rob
77 z650c1
77 z650c1
- PLUMMEN
23 Sep 2008 09:23
how about just getting a replacement swingarm so youarent down too long?
- judgie
23 Sep 2008 13:11
thats fine if you can find one, in the uk parts tend to be few and far between
77 z650c1
77 z650c1
