?92 ZX11 530chain/sprocket swap onto 83GPZ
- 83GPZ
22 Sep 2008 21:59
I have a donor 92 ZX11 with a blown motor. I a thinking about swapping the rearend as well as the front end on to my 83 GPZ1100. I just dont know if the front sprocket will fit my counter shaft. If this front sprocket will fill I will be able to kill two birds with one stone. ( I will get the 530 chain conversion and a 5.5/180 rear rim). Will I be able to use the swingarm as well? Anybody swapped to ZX11 front and rearend?
Thanks
Tee
Thanks
Tee
- StreetfighterKz
Re: ?92 ZX11 530chain/sprocket swap onto 83GPZ
23 Sep 2008 04:54 - 23 Sep 2008 04:54
According to JT Sprockets the sprockets will interchange but the offset is different, which may or may not work to your advantage. I think you'll find the swingarm too wide at the pivot point but you'll have to take measurements to find out.
Later, Doug
ZX11C sprocket
Later, Doug
ZX11C sprocket
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 23 Sep 2008 04:54 by StreetfighterKz.
- StreetfighterKz
23 Sep 2008 04:55
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
