Master cylinder repair?
- saltydog
17 Sep 2008 06:21
Has anyone tried to repair a the bore of a corroded brake master cylinder with epoxy. I am going to try it by coating the mc bore with epoxy to fill the pits in it and then ream it out to the right inside diameter.
I am talking with the tech people at West Systems Epoxy, but they aren't sure about the compatability with brake fluid. I should find out today.
I bought a new mc off ebay but I can't seem to make it work, too spongy. I suspect it may be too small, 14 mm, although they claimed it to be for a two rotor system. I seem to remember that the oem mc is 5/8, which is close to 16 mm. I will measure my old one before I do anything to it.
Any thoughts or suggestions will be appreciated.
I will report back on whether or not it works. I am going to try it, what have I got to lose?
Robert
Robert
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
- Zthou1977
Re: Master cylinder repair?
17 Sep 2008 06:51
Can't tell you anything about the epoxy, just thought I'd warn you that a using 14mm M/C for a two-disc setup is a sure-fire route into your local hospital or morgue. It will feel spongy, and then suddenly lock up. _Do not_ even try to use it, please...
Jeroen
Jeroen
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
- saltydog
17 Sep 2008 07:00
Thanks for the heads up, but why would it lock up?
Robert
Robert
- SPARKY47
- 1980 KZ500 B2
17 Sep 2008 15:12
mine had a 14mm with double discs on for years and never locked up.
1980 KZ500 B2
- steell
17 Sep 2008 19:07 - 17 Sep 2008 19:09
To answer your question about re-doing the bore on a master cylinder, the proper way is to bore it out, then make a sleeve that's a press fit into the now bored cylinder, then hone it to size. Some machinists have a nice little home based business going, doing just that.
Last edit: 17 Sep 2008 19:09 by steell.
- jonnybiker
17 Sep 2008 21:59
Jeesus, Why risk your safty on a tube of freaking epoxy? Or spend the money to have it resleeved? Spend a bit of cash and get the right master that works. Theese bikes are to fast and traffic to dam dangerous to screw around with your brakes. just my opinion. jonnybiker
- Zthou1977
18 Sep 2008 03:04
saltydog wrote:
Hi Robert,
They will lock up because of lack of "feel" in the brake lever. This site has a very handy chart to check for the best M/C-Caliper ratio: www.vintagebrake.com/mastercylinder.htm
Jeroen
PS: I'm with Jonnybiker, get a second-hand 5/8" master cylinder, do an overhaul and save money, time, and trouble.
Robert
Hi Robert,
Jeroen
- civilengr3
18 Sep 2008 08:01
saltydog wrote:
Mine had the smaller m/c with dual calipers. It locked up on me. Thankfully, I was just unloading it off a trailer and not on the road.
Too much pressure is exerted on the piston trying to pump enough fluid to a dual setup. It will probably be forever spongy feel, too, since it can't pump fluid fast enough.
Get a new/correct m/c!!
Robert
1977 KZ650C
East TN
East TN
- saltydog
11 Oct 2008 16:38
Well, I guess this will disappoint some of you, but the epoxy worked. I get a real sense of satisfaction in being able to fix things as opposed to replacing parts. To each his own.
- SPARKY47
- 1980 KZ500 B2
11 Oct 2008 17:04
What epoxy did you use?
1980 KZ500 B2
- PLUMMEN
11 Oct 2008 19:44
Zthou1977 wrote:
ive never had issues with small mastercylinder locking up,more of a rider preferance in my experiance.saltydog wrote:Thanks for the heads up, but why would it lock up?
Robert
Hi Robert,
Jeroen
