Chain too tight?
- SuperTrey
Chain too tight?
17 Sep 2008 05:53
I recently replaced the chain and sprockets on my 78 kz1000 a2. I went with the 503 chain and matching sprockets.
Since then, it seems to shift hard, or go into gear from neutral hard. Can this be caused by the chain being too tight?
- Old Man Rock
Re: Chain too tight?
17 Sep 2008 08:53
Measure the chain slack at the Midway point between cc and rear sprockets. The KZ900 specs recommend 1 1/4" distance of verticle travel for optimum performance... Not sure about the KZ1000 but should be ~ the same.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Royal1MC
- Is it just me, or is it just great to be on a KZ
17 Sep 2008 09:20
quote]
Quick question, is it a 530 chain with matching sprockets or did you convert both sprocket sizes to match the 630 gearing?
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Los Angeles, CA
- CoreyClough
- GPz550 Addiction
17 Sep 2008 09:42
Lube that clutch cable. You'd be amazed how much better it feels, and how easier you'll be able to find neutral. Worked wonders for me. If it's a new cable, lube it anyways, as it's not from the factory, or where ever you got it from.
'85 GPz550(ZX550-A2)
- SuperTrey
17 Sep 2008 10:52
Royal1MC wrote:
Quick question, is it a 530 chain with matching sprockets or did you convert both sprocket sizes to match the 630 gearing?[/quote]
it is a 530 chain with matching sprockets, but I changed the gearing slightly to reduce rpm at highway speed.
- Royal1MC
17 Sep 2008 11:53
What size srockets are you running in both the frt and rear, I current use a 17 frt and 43 rear. I am having the same issue @ hwy speeds.
Los Angeles, CA
Los Angeles, CA
- SuperTrey
17 Sep 2008 13:03
I will have to check I can't exactly remember. I will look tonight.
