Motorcycle uses of anti-seize
- MFolks
12 Sep 2008 14:28
I use the silver ant-seize sold at auto parts stores on many places on my motorcycle such as:
1. Sparkplug threads(a small ammount on an acid brush is all that's needed for easy removal and no more dreaded "stuck sparkplug")Remember to keep away from the center electrode as it is conductive.
2. The rear axle(makes installation and removal easier and reduces the rust problem).
3. Any stainless steel fasteners to prevent galling or sticking of the threads.
4. The engine bolts/screws that will stick due to dissimilar corrosion such as steel bolts/screws in aluminum cases.
5. The shock mount bolts will be easier to remove if they are first treated with anti-seize during maintenance.
Motorcycles are much like high performance aircraft in that both vibrate and want to lose parts. A good idea is to at least once a month go from the front of the bike to the rear checking the tightness of the fasteners.
A daily "preflight" or walk around should be done before mixing it up in traffic; things like chassis fasteners,tire inflation,lights,turn signals,brake and running lights and not to be forgotten the horn (lound and noticeable).
This is why Loctite,safety wire,self locking nuts,lockwashers and cotterpins were invented
- FastKaw1
Re: Motorcycle uses of anti-seize
12 Sep 2008 16:16
Could not have said it better myself...
I do use this stuff called vibertek (spelling) im no were near it to check.
It's not loctite, You can still get the parts apart, and it's not for places were you should use loctite. But for places like hand throttle, mirrors, head light bolts/screws
motor mounts.
You can't beet it, and it still douse a pretty good job on the corrosion.
XENU
motor mounts.
XENU
- NickW900LTD
- Nick
12 Sep 2008 18:40
I always use it on plugs and studs!!
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- PLUMMEN
12 Sep 2008 18:43
- Tony
Author
13 Sep 2008 01:10Please Log in or Create an account to join the conversation.
13 Sep 2008 04:13 - 13 Sep 2008 04:14
Tony wrote:
Thanks for the good link.
Most interesting and, to me, educational.
Last edit: 13 Sep 2008 04:14 by Patton.
- SPARKY47
- 1980 KZ500 B2
13 Sep 2008 06:28
PLUMMEN....is that nail paint?
Does it suit you?
Does it suit you?
1980 KZ500 B2
- Locozuna
13 Sep 2008 10:28
PLUMMEN wrote:
Does it come in Mother Kaw's Emerald Green? I'm also a little scared my bike may want to cuddle after riding.....:woohoo:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Tony
Author
13 Sep 2008 16:43
Patton wrote:
Your welcome Patton.
Tony wrote:
Thanks for the good link.Most interesting and, to me, educational.
