Any STOCK 750 Twin Exhausts Ever Seen In the Wild?
  • bountyhunter
  • bountyhunter's Avatar Topic Author
11 Sep 2008 20:01
#236791
All the talk about aftermarket exhaust systems... and the crummy performance of the MAC 2-1 I have on my 750 twin has me wondering:
Any stock 750 Twin exhaust systems available out there?
What would one in good condition cost?
  • RollingStock
  • RollingStock's Avatar
Re: Any STOCK 750 Twin Exhausts Ever Seen In the Wild?
11 Sep 2008 20:44
#236797
im pretty sure we have a stock one here at the shop i work at... i can check tom...
we got a bone stock 750 twin here for a chopp but motor had tranny problems so gsxr600 is gettting used in its place
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
  • bountyhunter
12 Sep 2008 16:05
#236899
If you do have an Kawi original stock exhaust in good shape that goes on a 1979 750 twin, I would like to hear about it.
Thanks.
  • steell
  • steell's Avatar
12 Sep 2008 19:27
#236927
You really don't like the Mac 2 into 1?
What did you find objectionable, or what problems did you have with it? I had one on a 79 and thought it worked ok, but my current 79 has stock 80 750G pipes on it.
  • bountyhunter
12 Sep 2008 22:12
#236937
Not so much.
It was a bugger to dial in. The off idle throttle response was terrible, I had to raise the needles all the way to get decent response..... and I had to crank up the pilot jets to #50.
It runs just OK. Power is decent, but not as good as stock especially at low RPM where I cruise 95% of the time (2 - 3k). It does not run as well as the stock pipes did, and way less than the Kerker style aftermarket pipes.
The gas mileage also is down from about 40 mpg to 36 mpg (all city driving). The reason is obvious: I have to open the throttle more to get the same amount of power.
The MAC that I have may be screwed up, I have nothing to compare it to. The thing leaks exhaust at both pipe connections. Thay may be screwing up the tuning.
  • RollingStock
16 Sep 2008 07:44
#237357
just check to see if it was a whole stock exhaust and what not.. sure is.. bike ended up getting hacked up... so custom frame is being made.. motor has sum kind of tranny problem.. so its more or less for parts now..
exhaust looked pretty clean.. little rust on the cross pipe but other than that its all there.. rust isnt that bad.. i can get sum pics if u want.. let me know if u need anything else
  • bountyhunter
16 Sep 2008 15:45 - 16 Sep 2008 15:52
#237403
Sounds interesting.
Do you know the year and model of 750 twin it's off?
Rust is only cosmetic?
No serious dings or damage?
All the keepers/brackets/hardware stuff with?
Can I ask what the cost would be?
I appreciate your time looking into it. Pics are always interesting if not too much trouble.
Last edit: 16 Sep 2008 15:52 by bountyhunter.
  • RollingStock
16 Sep 2008 17:06
#237412
ill find out all the info for u tom morning and take sum pics for u
  • steell
  • steell's Avatar
16 Sep 2008 18:22
#237420
bountyhunter, IMHO you wouldn't be happy with the 80 750G exhaust, I have that on my 79 and it just don't look as good as the 76-79 exhaust.
I don't know what year exhaust RollingStock has, just thought I'd mention the 80G just in case.
  • bountyhunter
16 Sep 2008 21:07
#237456
I'm not that worried about looks... you should see my bike. It's looks as bad as it's owner.:laugh:
I was thinking of getting a stock exhaust because the cross pipe setup has better low RPM pull, it's quieter and the mileage was better.
TELL ME: is it hard to fit one of these G exhausts to a '79 model B4?
  • steell
  • steell's Avatar
17 Sep 2008 05:27
#237475
The 1980 KZ750G exhaust bolts on the 76-79 750B, but you do have to make short mounting extensions so the mount will reach the rear footpeg mount on each side.
  • bountyhunter
17 Sep 2008 12:59
#237540
OK
