Swingarm Bushing Removal
  • letthegoodtimesroll
  • letthegoodtimesroll's Avatar Topic Author
10 Sep 2008 16:28
#236610
I am replacing my swingarm bushings and am wondering if there is any particular way to remove them or do you just use a drift and knock them out? Any and all help is appreciated:)
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
  • RonKZ650
  • RonKZ650's Avatar
Re: Swingarm Bushing Removal
10 Sep 2008 19:18
#236631
There's some good news and some bad news as is always the case :) The good news is yes they come right out. Remove the swingarm, tap out the center tube, then tap out each bushing. They come right out. All is cool and easy to this point. Next tap in the new bushings. All is easy. Next install the tube. This is where the bad news comes in, the tube will not fit in the new bushings. Because the old bushings were worn, rust and the like has grown on the tube and the tube is bigger diameter than the bushings allow. So get out your emory cloth and start on the tube. It will take an hour or two to massage it into shape to fit, or preferably you bought a new tube to go with the bushings and then it's all easy going.
11 Sep 2008 16:06 - 11 Sep 2008 16:08
#236740
I quickly tried mine last night and they didn't come out but I only tried for a couple of minutes as it was getting late. The tube fits into the new bushings fine so I am wondering if it is the bushings at all, maybe it's the tube as there is lateral movement in the swingarm. I will replace them as I have new ones and then I will know.
Last edit: 11 Sep 2008 16:08 by letthegoodtimesroll.
