Aftermarket Master Cylinder - Not big enough?
  • supercharged
  • supercharged's Avatar Topic Author
05 Sep 2008 22:39
#235748
When going through a new purchase of mine - 80 1000 LTD, I noticed the brake fluid looked like tar, so while changing the rubber, I added new pads and started to change the fluid and found the master cylinder boot was stretched open worn thin on the edges, since it was missing the gasket between the lid and the boot.
Since I have a hydrolic clutch that used a universal master to run that, I thought I would buy a matching master for the brakes and solve my problems...
Upon assembly and the dreaded bleeding of the front brakes, I find myself with no apparent air left in the system and a brake lever that has resistance, but can still be pulled all the way to the bars.:S
After over a pint of fluid through the system - 1st with vacuum, then with standard pumping... I thought I would get an opinion.
Is it possible that the new master won't produce enough pressure? Or do I continue to bleed...
This is a link to the part
Any ideas?
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
  • fixer5000
  • fixer5000's Avatar
Re: Aftermarket Master Cylinder - Not big enough?
06 Sep 2008 00:45
#235757
you may want to do a search here for more info but it seems one of the best ways to get those last few air bubbles out is to wire tie your brake lever to the bars and let it sit overnight...steve
1978 kz650b pretty much stock
massachusetts
  • Samwell
  • Samwell's Avatar
06 Sep 2008 02:42
#235760
Well, it lists a 13mm piston. If memory serves most Kawi's have a 1/2 inch piston with single disc front brakes and 5/8 inch with dual discs. 13mm is 0.512 inch so I figure that its close enough to be just fine. More than likely there's a bubble trapped somewhere.
Sam
Any ideas?
  • JMKZHI
  • JMKZHI's Avatar
Re: .
06 Sep 2008 05:38 - 04 Dec 2008 09:38
#235767
del
Last edit: 04 Dec 2008 09:38 by JMKZHI.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
07 Sep 2008 07:36 - 07 Sep 2008 07:38
#235941
Mike,I had to hang my calipers(from string) at a different angle to get the remaining air bubbles out.
It worked great.B)
Put a piece of wood in between each set of pads to keep them from collapsing.;)
1977 KZ1000 A-1
Last edit: 07 Sep 2008 07:38 by Sandy.
  • supercharged
07 Sep 2008 15:00
#235998
Well the master may be a bit small, but since these are single piston calipers... I go for it.
I did tie the lever to the bars overnight and that seems to work. I have about 50% of movement now.
Rode the bike and they worked... and worked good.
Thanks for the suggestions.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
