kz750 twin sprocket
  • jorn
  • jorn's Avatar Topic Author
  • vroooooommmmm
kz750 twin sprocket
02 Sep 2008 02:24
#235092
I'm wanting to get my '80 kz750-g1 to run at a more comfortable rpm on the interstate. has anybody changed sprockets on one of these bikes with this in view (steell?)? any suggestions on what sprockets to use and where to get them? Thanks in advance guys.
______________
1980 KZ750G LTD Twin (basket case)
  • steell
  • steell's Avatar
Re: kz750 twin sprocket
02 Sep 2008 05:27
#235101
17 tooth countershaft sprocket works well, many here (including me) use it.
Z1 Enterprises is where I buy mine.
  • ronjones
  • ronjones's Avatar
02 Sep 2008 11:14
#235141
Yep
  • bountyhunter
  • bountyhunter's Avatar
02 Sep 2008 11:39 - 02 Sep 2008 11:42
#235145
I am running the 16T standard front with a 32T rear. 32T is the smallest you can go in the back. That gives a 2.00:1 ratio. If you go from 16T to 17T on the front, that's only about a 6% reduction in RPM and Id efinitely wanted more than that. Going from 38T to 32T in the back drops the RPM about 16%. For me, that dropped 70mph RPM from 5000 down to about 4200.
I didn't see any reason to buy two sprockets to change the gearing, so I just changed the back.
I am totally happy with the performance, but I weight 165 and don't hot rod much.
I recall I got mine from a place that had a name like "sprocket specialties" or maybe "sprocket specialists" or something that sounded like that. It is a hardened aluminum sprocket as opposed to steel but it wears forever so it must be good.
Last edit: 02 Sep 2008 11:42 by bountyhunter.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
04 Sep 2008 17:58
#235540
(Including me, too.)
:laugh:
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • steell
  • steell's Avatar
04 Sep 2008 21:29
#235571
Guess I should clarify :)
I used a 17 tooth countershaft sprocket on all the 750 twins I have had, but they have all had 16" rear wheels, either Morris Mags or the G rear wheel. And Morris Mags use a 37 tooth rear sprocket stock.
  • jorn
  • vroooooommmmm
10 Sep 2008 03:11
#236476
ok. i'm using the stock mag, and she cruises at 75 at right around 6k rpm. it hurts me inside to run her like that.
i'm not sure how to calculate the rpm drop, but i was thinking about going with the 18-tooth countershaft to start out with and if that didn't drop it enough to try reducing my rear sprocket size. will the 18-tooth fit alright/
please pardon my broken shift keys. that sentence was meant to be a question :laugh:
______________
  • steell
  • steell's Avatar
10 Sep 2008 05:33
#236490
17 is a fairly tight fit, to use an 18 you'd probably have to remove the guard in front of the sprocket.
75 mph has been the "sweet spot" (the speed at which everything just feels right) on my 750 twins with the 17/38 or 17/37 sprockets and 16" rear tires.
  • bountyhunter
10 Sep 2008 15:53 - 10 Sep 2008 15:54
#236597
Easy to calculate the RPM drop: if you start with a 16T front and go up 1T, the RPM will drop by 1/16 or the final RPM will be 15/16 of the original.
If you start with a rear of 38T and go to 32T (like I did), the RMP will drop by 6/38, or final RPM will be 32/38 of original.
BTW, mine cranked 5000 @ 70MPH stock, so it dropped to about 4200 RPM @ 70MPH after changing the rear sprocket from 38T to 32T.
I don't think an 18T will fit on the front, I know a 32T fits on the back because I am running one now.
Last edit: 10 Sep 2008 15:54 by bountyhunter.
