Fork oil Seals
- SPARKY47
- 1980 KZ500 B2
Fork oil Seals
01 Sep 2008 14:38
Evenin' All:)
Now every so often someone posts on this forum and we all fall about laughing,well tonight I'm the idiot because I'm going to ask if someone could help me with a quite frankly laughable question. Here goes...
Decided the lower fork tubes are shiny enough,[and anyway my fingers are different lenghts from all that rubbing]and its time to re-assemble them.
Bought the trapizoidial[whatever!]weirdo tool to hold the CYLINDER-FORK to enable tightening of THAT allen bolt in the bottom of the forks.
It doesn't fit:angry:
Fuck it, do it the old fashioned way. Got a broom handle and a stanley knife out,did a bit of superb engineering and rammed the handle into the CYLINDER-FORK to hold it.
Bolt is now tight.
Time to put the new oil seal in...
On close inspection, I see that this thing is meant to go in one way only because there's a circular coiled spring visible on one face and not on the other.So I look in the manual, nothing, no indication of which way round it goes in.
Then to make matters worse... the SPACER-FORK,which is a fancy cup shaped type washer isn't shown in sufficient detail for me to know which way up it goes in[sits underneath the seal].
I knew I should have photographed dis-assenbly but I didn't so now I have two components,each of which can go in two ways, and no idea.
Please can someone tell me which way up these things go in?
Many Thanks in advance for any help with this.
Bolt is now tight.
1980 KZ500 B2
- SPARKY47
- 1980 KZ500 B2
- KZQ
- Administrator
Re: Fork oil Seals
01 Sep 2008 17:42 - 01 Sep 2008 17:53
Hi Sparky,
The broom stick method works well for disassembly however part of the routine is that once you have it apart you can see what it will take to hold it from turning during reassembly. If you used a broom stick on reassembly hopefully not too many wood fibers scrubbed off the broomstick to contaminate the fluid afterwards. I've generally found that using an impact wrench alone often results in a chewed up crush washer.
If you would post the year and model of your bike, in your signature line, we'd be glad to look up the parts diagrams and give you advice on the proper reassembly. I know for certain that some bikes need the steel ring above the seal and other need the ring below the seal.
Hope it works for you.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Last edit: 01 Sep 2008 17:53 by KZQ.
- SPARKY47
- 1980 KZ500 B2
Re: Fork oil Seals
01 Sep 2008 17:53
KZSCI,Thankyou for your response,the diagrams I have show the steel ring below the seal but don't describe it's orientation.[It's not flat,kind of like a doughnut cut in half and hollowed out].
Thanks for the info on the orientation of the seal itself,I guess I'm going to have to start using this fancy camera a bit more in future:)
Again, many thanks.
Again, many thanks.
1980 KZ500 B2
- KZQ
- Administrator
Re: Fork oil Seals
01 Sep 2008 17:57
Hi Sparky,
If the diagrams do not show enough detail all you've got is us. Can you post the year and model of your bike? Perhaps someone who has been there can help.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- SPARKY47
- 1980 KZ500 B2
Re: Fork oil Seals
01 Sep 2008 18:01 - 01 Sep 2008 18:24
KZSCI,I've just been looking at my details,avatar,etc and don't see how to add my model details underneath the picture, could you possibly give me some pointers wrt this please?
I have to say I'm impressed that I seem to be a moderator though!
Got it! Had to logout then back in.
Still a mod though:silly:
1980 KZ500 B2
Last edit: 01 Sep 2008 18:24 by SPARKY47. Reason: I'm old and deranged
- jonnybiker
Re: Fork oil Seals
01 Sep 2008 18:36
Perhaps i misunderstood, are you trying to install seal with fork tube installed in lower? seal goes spring down towards axle, half donut piece goes round side up towards handle bars, under seal,between seal and axle. fork tube must be out of lower before seal can be installed. hope this helps a bit. jonnybiker
- KZQ
- Administrator
Re: Fork oil Seals
01 Sep 2008 18:37 - 01 Sep 2008 18:39
"I have to say I'm impressed that I seem to be a moderator though!"
Here at KZR we've decided that field commissions help with moral a bunch!
Sorry, just a small joke, once Tony, Nate or myself have posted in a thread everybody becomes a moderator.
Johnny Biker's got the right info, Go with it!
Thanks
Bill
KZCSI
Thanks
Bill
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Last edit: 01 Sep 2008 18:39 by KZQ.
- SPARKY47
- 1980 KZ500 B2
Re: Fork oil Seals
01 Sep 2008 19:10
jonnybiker,thankyou very much.All is now clear:)
KZSCI, so I'm not a mod:ohmy:
better hang round for a while thenB)
Thanks Guys,could never do this without the knowledge on this site.
1980 KZ500 B2
- coppertales
Re: Fork oil Seals
02 Sep 2008 12:56
A piece of plastic pipe, 1 1/2 dia, I think, makes a dandy seal seating tool with the tubes installed. Be sure to lube the tubes so the seal slides down them easily......Oh, for the challanged individuals, the plastic pipe needs to be longer than the tube so you can hit it with a mallet....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- SPARKY47
- 1980 KZ500 B2
Re: Fork oil Seals
02 Sep 2008 14:44 - 02 Sep 2008 14:45
Coppertales..Thats a good method,I used the old seal as a shield and a rubber hammer,[tubes not installed!]but next time,it'll save removing tubes:silly: Thankyou.
The other leg's waiting for the earpaint to dry:woohoo: :silly:
1980 KZ500 B2
Last edit: 02 Sep 2008 14:45 by SPARKY47. Reason: I'm old!
- KZQ
- Administrator
Re: Fork oil Seals
02 Sep 2008 15:15
If I'm just doing seals and the fork legs are in good condition. I leave the fork tubes in the triple trees and use a piece of 1 1/4" plastic pipe 4" long that I've split lengthwise as a seal driver. Use two hose clamps to secure the two pieces of plastic pipe to the fork tube. Then just slide the seal onto the fork tube follow with the steel washer then the fork slider and using the fork slider like a slide hammer I drive the seal into the recess in the fork slider.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
