Sight Glass Problem
- Silver
- Old Bikes Are Better!
Sight Glass Problem
01 Sep 2008 05:22
Beetween my micro at work and online I cannot seem to find a replacement sight glass for my front master cylinder.
Any Suggestions? I cannot even see through mine the plastic is really foggy and spider cracked.
1983 KZ750F1 LTD
- bill_wilcox100
Re: Sight Glass Problem
01 Sep 2008 05:38
You will want to add your year, model and location to your signature to get an informed response and it's considered real friendly too. :dry:
In the mean time, Z1 Enterprises may be useful to you:
www.z1enterprises.com/
Best of success.
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- Silver
01 Sep 2008 05:54
Sorry. I dont know how to make that happen....ill work on it.
Till then
1983 Kz750f1 ltd shaft
Till then
1983 KZ750F1 LTD
- Sandy
- Fly High,Tony
Last edit: 01 Sep 2008 07:51 by Sandy.
- wiredgeorge
01 Sep 2008 07:52
Silver, You go to the Z1Enterprises.com website and get their phone number. On Tuesday, give them a call. They have new sight glasses in stock. You remove your case cover that holds the sight glass and drive it out and install the new one with just a little coating of JB Weld. Most of them are really foggy and unfortunately, Kaw chose to put a mesh screen behind the glass so they are hard to clean but if you take the cover off and cut the mesh off, you can clean the glass easily. The mesh doesn't seem to serve a pupose. I doubt the clear plastic is cracked and the old one might clean up OK. Use a new case cover gasket.
- Silver
01 Sep 2008 08:00
Think ill go with a whole new master. That plastic lens is soft to the touch even. I can get that same master through my aftermarket books at work too. hadn't thought of the idia of full replacement. Thanks for the tip on those lenses too. I have another in the works project that could use a lens.
1983 KZ750F1 LTD
- Sandy
- Fly High,Tony
01 Sep 2008 08:05
Well there you go,Silver.
And as far as the purpose of the meshing behind the glass,pretty sure it's there to make the level-line(or bubble) more visible.
1977 KZ1000 A-1
