output shaft diameter size question
- galaxian
17 Oct 2005 10:36
Does anyone know the diameter of the output shaft on the front sproket for the 650 and 900? I need to know if they are the same of differnt sizes.
1977 KZ1000A1, 1979 KZ650 C3
- OnkelB
Re: output shaft diameter size question
17 Oct 2005 11:23
I did some research on this subject a while back - check the last post in
this thread
for details. Also check the link to JT that Jeff posted there, very useful.
The 650 and 900 output shafts are the same (25mm/13 spline), but the sprockets are not as the 900 uses a 630 chain.
Post edited by: onkelb, at: 2005/10/17 15:53
77 KZ 650 B1, 82 GPz 1100 B2.
- galaxian
17 Oct 2005 12:14
Thanks for the info. I ended up calling who else...Z1 enterprises and as usuall Jeff had tons of great info. He acutually pointed me to this web site great stuff.
Go here www.jtsprockets.com/52.0.html enter your bike and see the specs on your sproket.
Brilliant!
Oh if Jeff if you read this. THANKS!
Post edited by: galaxian, at: 2005/10/17 15:15
Brilliant!
