Front Fork Swap / Upgrade?
27 Aug 2008 02:17 #234180 by iandz500
Front Fork Swap / Upgrade? was created by iandz500
I’m looking to upgrade the front end of my 1980 Z500B, does anyone know what diameter the front forks are?
Would it be sensible/advisable to mill out the yokes to accept a slightly larger diameter fork (2-3mm bigger at most)?
Ideally I’d love to go down the USD fork route but this seems like a lot of work and most USD set ups seem to be very wide between the forks?
What bikes have other people fitted forks off?
Bikes: 1960 lambretta Li125 sold; 2001 Honda CG125 sold; 2006 Yamaha FZ6 sold; 1980 Kawasaki Z500 sold; 1967 BSA Bantam D10; 2008 Aprilia Shiver sold; 2010 KTM Duke 690R; 1954 BSA Bantam; 1980ish Kawasaki Z200
28 Aug 2008 12:45 #234462 by galaxian
Replied by galaxian on topic Front Fork Swap / Upgrade?
First off you need to measure your forks!!
Secondly, both the 650 and the 1000 have 36mm forks. If yours are smaller perhaps this would be a decent upgrande especially if you went with progressive springs as well.
If you want upside down forks then chances are you will need to convert your rear end as well if you want matching wheels and modern rubber. I have converted my kz1000 forks to zx7r upside down ones. It was a fairly easy and straight forward conversion. Infact i would call it easy. The rear was quite a differnt story.
1977 KZ1000A1, 1979 KZ650 C3
  • Skyman
28 Aug 2008 13:07 #234464 by Skyman
Replied by Skyman on topic Front Fork Swap / Upgrade?
Galaxian, can you please expound on this a bit? Why would you need to make a change to the rear end after converting to inverted forks? Is it an issue of switching to radial tires?
West Linn, OR
28 Aug 2008 13:14 - 28 Aug 2008 13:18 #234465 by galaxian
If you fit an USD fork from a modern bike the front tire will be a 120/70/17 or 120/80/17 give or take and your old rear tire will be a 130/80/18 at best. This does not make for a good handling combination. Not to mention it wont look good with a modern front wheel and a stock rear wheel.
Last edit: 28 Aug 2008 13:18 by galaxian.
