sterring dampner
- tanner
sterring dampner
25 Aug 2008 16:28
im putting on a sterring dampner on my 1975 z1900 is there any special kind of bolts i should use to connect this to the bike?
- MFolks
Re: sterring dampner
25 Aug 2008 19:04
How are you going to secure it to the frame and bars/tripple tree? Some drilling might be needed to mount the dampner. I'd use what the manufacturer suggests or the strongest AN/NAS bolt that would fit the ends.
The website www.arp.com lists some really strong stuff,give them a look.
- MFolks
26 Aug 2008 09:30
The correct website for ARP shold read
www.arp-bolts.com
- FastKaw1
26 Aug 2008 12:29
ZI Had frame and steering mount from the factory.
Use grade 8 bolts.
The frame mount should have a corner brace welded in. They are notorious for
bending or braking at the frame.
In most cases a set of roller bearing on the steering stem is more bang for your dollar. Im my opinion.
XENU
Use grade 8 bolts.
XENU
- 1973Z
27 Aug 2008 06:57
That was the first accessory I installed on my new Z1 35 years ago. The triple tree and frame had a hole and bracket already there. The damper still works, it never leaked, and I never had any problem with wobbling. I put in the roller bearings in the steering head a couple years ago.
