Chain Makeing noises
  • takuma
  • takuma's Avatar Topic Author
20 Aug 2008 09:58
#233104
I just got a KZ305 and I noticed the chain was way to loose. It was sagging so much that it was touching the frame. So I adjusted it and tightened it up but now it is making a clicking type noise in the front as well as in the back.
As far as I can tell I have it aligned and at the correct tension. Does anyone know what my problem may be? Thanks
  • KOOL RYDER
  • KOOL RYDER's Avatar
  • KZ 650B2 / KZ 1000E
Re: Chain Makeing noises
20 Aug 2008 10:05
#233107
If it is making noises, clicking it is most likely binding and is worn out.
Go to Z1 and get a new chain. Some new sprockets are cheap as well.
In the mean time, assumng that everything is alligned properly, then clean and oil the chain. Put a lot of oil on it and see if that helps.
You should oil your chain regualarly to ensure that it does not fail on you.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
20 Aug 2008 11:20
#233119
Many years ago I was planning a trip to Montana from Oregon. I knew my chain was worn so I elected to replace it. I'd been told to replace the sprockets while I was at it but being headstrong I reckoned that I only needed to replace the countershaft sprocket being as it had the fewest teeth. The rear sprocket looked fine so I went with it. I did the swap the day before I was to leave. I even used an endless chain which meant I had to pull the swing arm to install it. Any way a couple of hours into the trip I realized that the rear sprocket was buzzing whenever I was on the gas and ran quite whenever I was coasting.
I ended up pulling over to the side of the road where I removed the rear wheel and flipped the sprocket over so that the bike ran quietly while on the gas and buzzed whenever coasting. I finished the remainder of the 1200 mile trip that way.
Needless to say I redid the whole job when I got home, sprockets, chain and all.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
