Where can I find a Front Master Cylinder Boot?
  • badrhino
  • badrhino's Avatar Topic Author
19 Aug 2008 20:28
#233021
I have a 1980 KZ1000 with the triaglular looking master cylinder resevior. The boot is stretched out pretty bad and was needing to find a new one. You can barely fit it back in the resevoir let alone any fluid. Any suggestions?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Where can I find a Front Master Cylinder Boot?
19 Aug 2008 21:01
#233027
Are you referring to #5 in the attached pic?
Also,Rhino...put your bikes'"Model" in with your signature.
(A4,B4,C3,etc.)
It will make a difference in some cases.
1977 KZ1000 A-1
  • badrhino
19 Aug 2008 21:36
#233029
Sandy, Yes #5 is what I am looking for!
Franken Z!
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
19 Aug 2008 21:54
#233031
OK,just to be sure.(I figured that's what you were talking about)
You can check with Jeff at,
www.z1enterprises.com/
I'm not sure if they're available there or not,but give him a call and ask.
If he doesn't have anything,he might be able to steer you in another direction.
1977 KZ1000 A-1
  • Royal1MC
  • Royal1MC's Avatar
  • Is it just me, or is it just great to be on a KZ
19 Aug 2008 22:20
#233037
You might also want to contact your local Kawasaki dealer you will be suprised what you can order still order from them.
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
  • JMKZHI
  • JMKZHI's Avatar
Re: .
20 Aug 2008 06:22 - 04 Dec 2008 07:23
#233063
del
Last edit: 04 Dec 2008 07:23 by JMKZHI.
  • smclem
  • smclem's Avatar
  • www.osrbikes.com
20 Aug 2008 08:58 - 20 Aug 2008 09:00
#233091
yes these are available $20.60 let me know if you need help getting one. Kawasaki is Getting low on quantity avaiable so it probably won't be long till the are NA!
1976 KZ900
2006 ZX14
08 KLX110
09 KVF750 Brute Force
1974 KE100
Last edit: 20 Aug 2008 09:00 by smclem.
  • RonKZ650
  • RonKZ650's Avatar
20 Aug 2008 09:55 - 20 Aug 2008 10:00
#233103
You probably know, but just in case, the diaphram is retractable. Simply squeeze back to original shape after it's stretched. The way it works is fluid is drawn from the master cylinder after brakes begin to wear and space has to be taken up by something, so the diaphram stretches downward to take up the space as air is allowed on top of the diaphram. This way the system is sealed from the elements yet can still allow brake fluid level change. The diaphram will never revert to original shape without aid. Like I say, you may know this, but I've never seen a diaphram that wont accordian right back to recessed.
Last edit: 20 Aug 2008 10:00 by RonKZ650.
  • badrhino
20 Aug 2008 15:41
#233160
Yes, I know they are retractable it is just that this one is so old and weathered or what no that it will no go back to original form. Thanks
Franken Z!
  • supercharged
  • supercharged's Avatar
01 Sep 2008 01:42
#234915
Mine was stretched the same way... currently replacing the MC with and aftermarket, but here is a source for a boot to:
www.redlinecycle.com/Brk%20-%20Mast.%20C...Seal%20-%20Trap.html
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
