Modern brake calliper and rotor on a 74 z1?
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
18 Aug 2008 21:21
#232821
I was just wondering if there was a modern style caliper and rotor that i could bolt onto a 74 z1? I can make an adapter plate for the calliper so that isn't a problem, are there any newer bikes were the rotor would bolt up to the z1 hub? Or would i be ok with just putting say a GSXR calliper on the stock z1 rotor? Thanks guys.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • steell
  • steell's Avatar
Re: Modern brake calliper and rotor on a 74 z1?
18 Aug 2008 21:46
#232824
Most of the GSXR calipers are opposed piston design I believe, meaning they have pistons on both sides of the rotor, and if that's the case (and I think it is), I doubt you will have enogh clearance between the rotor and the wheel to fit one on there.
If your objective is more stopping power, then you could get the calipers off a 83-85 GPz750 or 83-84 GPz1100, the GPz's of those years use 10" rotors, and when you stick those calipers on a 12" rotor the stopping power is increased.
The 76-80 750 twins use the same rotors as the 77-79 1000's, so I put the drilled rotors off a 79 1000 on my 750 twin, and originally used the 1000 calipers. I switched the calipers to 83 GPz750 and was amazed at the increase in stopping power.
Maybe they will work on your bike.
  • oldkaws4ever
18 Aug 2008 22:31
#232830
Thanks Steell il look into that. I wonder if there are any modernd day rotors that would bolt up to the z1 hub?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • WPBill
  • WPBill's Avatar
18 Aug 2008 23:51 - 18 Aug 2008 23:54
#232837
Jeff at Z1 Enterprises sells a full floater rotor that bolts onto a Z1 hub.I've one on my 75. Bee You Tea Full!
www.z1enterprises.com/detail.aspx?ID=2606
ZPower Australia sells a bolt on twin piston caliper, both LH and RH.
Soon as I get some more free cash...
www.zpower.com.au/catalog/product_info.p...5_93/products_id/255
Pretech (UK) sells a bolt on six piston caliper.
www.pretech.co.uk/
You can only be young once, but you can be immature forever!
Kamakura JAPAN, 1975 Z1B (x2, both in storage)
Last edit: 18 Aug 2008 23:54 by WPBill.
  • z19OO
  • z19OO's Avatar
20 Aug 2008 14:35
#233145
Lot of the triple guys use a ex500 caliper with a custom bracket. That should work on z1 as h1/h2 stock calipers will bolt on a z1. I have one on my H1 and stops like a mother f**ker. Might sell as I like the period correct stuff.
1975 z1 900
1979 kz650b
