Building new drag chassis on a budget
- iroc355
Re: Building new drag chassis on a budget
25 Aug 2008 06:26
and the kawis have 40 spokes right?
- iroc355
25 Aug 2008 10:47
just came across a local guy with a brand new 1.85x18 wheel, 40 hole design.
i can pick it up cheap, is this a good front wheel to pick up?
- tw..
26 Aug 2008 05:17
iroc355 wrote:
The biggest thing I would be concerned with is if you can find bearings that will fit the wheel and axle you plan to use and make sure the tire is not too wide to fit between the forks.
so ive found an awesome deal on a set of 3 spoke aluminum wheels off a 96' GPZ 1100, should i bother with them?
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
1978 Z1R
- StreetfighterKz
- Online
When I swapped the Zx11C front rim into my police forks, I just went to the local bearing supplier with the old bearing and said I need the same bearing but with ??mm ID instead. They had what I needed in stock.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 26 Aug 2008 08:51 by StreetfighterKz.
- iroc355
26 Aug 2008 15:28
i think for my first bike maybe im just gonna run a stock front end, front wheel and find a wider rear rim for my slick since were building my swingarm.
- Kawiman80
- On my 2nd KZ1000
05 Sep 2008 19:00
Hey there iroc. I am to building a drag bike on a budget. I found a 18x3.5 rim from a 54-72 (gulp) Harley Sporster for $40 at a local swap shop. It is Aluminum also. You can run a 5.5x18 slick on the rear with a custom swing arm with no problems. I am running a 19incher on the front for now. It runs mid to high 6's in the 8th mile,no whellie bars,foot shiftin! You can use almost any 40 spoke rim laced to disc brake KZ hub. Mine is a KZ750 hub. NO problems.And no bracing on the frame,but it is and 80 also. I would recommend using a later frame and restoring the 73. But,then again it's not my bike. Good luck and don't rush it! I need to post new pics,so don't go off the one in my profile.
1980 kz1000g 1105 34mm Mikuni flat slides Kerker exhaust custom paint stock ignition(Dyna 2000 soon) Accel coils and wires stock cams w/ heavy springs for more rpm. My 2nd 1000.
