Building new drag chassis on a budget
- smclem
- www.osrbikes.com
Re: Building new drag chassis on a budget
21 Aug 2008 09:43
yeah but the 11 second bikes don't really twist the frames to much-- i would worry about other things first .
1976 KZ900
2006 ZX14
08 KLX110
09 KVF750 Brute Force
1974 KE100
2006 ZX14
08 KLX110
1974 KE100
- iroc355
21 Aug 2008 14:12
im looking to run a 7" slick, im planning on running in the area of 10's-11's.
as for the swing arm, my father in law is building me one, he's made a few different ones already.
i'll keep my eyes open for a 650 front end and 200 front wheel.
thanks for the help guys, keep the opinions coming!
- donthekawguy
21 Aug 2008 17:18
As long as you have the bike apart go ahead and spend the $30 and a couple of hours and brace it up. Also a 18 inch front slick is easier to find than a 19incher. Go for the 18 inch. i sold one about 6 months ago or it would have been yours.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- iroc355
21 Aug 2008 17:59
now as far as wheels go, what do i need to look for or change to put a different wheel on? what specs do i need from the wheel? (for front and rear)
- smclem
- www.osrbikes.com
22 Aug 2008 05:21
1.85 x 18 is a good front to find
1976 KZ900
2006 ZX14
08 KLX110
1974 KE100
2006 ZX14
08 KLX110
1974 KE100
- Jack
22 Aug 2008 06:29
H1/H2 or S2 triple front ends will work too, and have the 18" wheels. You'll have to replace the S2 steering stem with the one from the Z1 to use that front end but the H1/H2 forks are a drop in deal to Z1 trees.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- donthekawguy
22 Aug 2008 14:49
You could probably just lace up a 18 inch rim to the kz hub.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- iroc355
22 Aug 2008 15:09
sorry if i seem a lil stunned........
so will any wheel lace up to z z1 hub? and if i decide to go with like a cast aluminum wheels, how will i know what specs to fit the front and rear?
im new to all this bike stuff so bear with me lol
- iroc355
23 Aug 2008 06:14
so ive found an awesome deal on a set of 3 spoke aluminum wheels off a 96' GPZ 1100, should i bother with them?
- StreetfighterKz
- Online
23 Aug 2008 14:53
Those rims are very close if not the same as ZX11 rims. You will need a sportbike, or the Kz police model, front end to use the front rim as it uses a wider hub and will not fit inside the stock forks without serious machining, custom spacers and bearing swaps.
The rear will probably be OK since your having a custom swingarm made and can factor the wider hub into the equation when having the arm built.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- iroc355
23 Aug 2008 17:34
so i should probably just track down some spoked wheels hey. wheres the best place to find sum? i know the father in law can lace me sum up.
- donthekawguy
25 Aug 2008 06:03 - 25 Aug 2008 06:04On this bike I used a rim from a motocross bike that had the little spikes on the inside of the rim to grab the tire. That was back in 1993. When looking for a rim just make sure the rim has the same number of holes as the hub. Damn I wish I would have kept that bike.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Last edit: 25 Aug 2008 06:04 by donthekawguy.
