Front End Swap KZ750
  • KZ802
  • KZ802's Avatar Topic Author
16 Aug 2008 16:36
#232385
I have a '80 KZ750-4 LTD. I also have a mid '80s complete GPZ 1000 front end. Anyone know the easiest way I can make these work together? I have a complete '81 kz750 parts bike so I took off the head stock to compare the triples and fork tubes etc. They are close but no cigar. GPZ forks are obviously a little bigger(larger diameter), and a little farther apart.
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
  • steell
  • steell's Avatar
Re: Front End Swap KZ750
16 Aug 2008 23:27
#232431
All Balls will probably have the bearings you need to do the swap. I put a 99 GSX front end on my 80 750E, and GPzInfested put a 83 GPz750 front end on his 79 KZ650SR using bearings from All Balls. Cost right around $40 for each bike.
  • moparjan
  • moparjan's Avatar
19 May 2013 00:16
#588138
I recently purchased a 1980 KZ750 4 ltd and I was wondering which front end swap would be best. I really like the look of the big round discs on alot of sport bikes. I'm keeping everything cruiser I just want to stop better.
twist it
  • steell
  • steell's Avatar
19 May 2013 00:40
#588141
My recommendation is to measure the unloaded length of your forks, shop around for a setup (Hopefully complete with brakes, wheel, and triple clamp would be nice) that you like, then have a member here make you a new triple that fits your frame and your new forks, or just a stem.
I'm a little embarrassed because I can't remember his name, but I've finished two quarts of frozen Margaritas so far. :P
  • moparjan
  • moparjan's Avatar
19 May 2013 03:14
#588152
Can that same member make a rake set of trees?
twist it
  • steell
  • steell's Avatar
19 May 2013 15:05 - 19 May 2013 15:12
#588191
At least two members make front end conversion stuff.
531blackbanshee and This Thread
Les Holt, his bike was recently featured in a magazine I believe. You can read about it here, and PM Les
Both do quite nice work.
Last edit: 19 May 2013 15:12 by steell.
