Steering head or neck angle of kz900?
  • OldSchoolHr
  • OldSchoolHr's Avatar Topic Author
  • Kawasaki z900a4 1976 Croatia, Europe
11 Aug 2008 13:36 - 11 Aug 2008 14:16
#231394
Does enyone know how many degrees is steering head (or neck )angle of kawasaki kz900?
Last edit: 11 Aug 2008 14:16 by OldSchoolHr.
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Steering head or neck angle of kz900?
11 Aug 2008 16:57
#231425
Not sure I'm understanding your questions.
Are you speaking of turning radius (angles) or the rake?
Turning Radius is 41 degrees off center.
Caster is 64 degrees.
Or are you speaking entirely of something else...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • OldSchoolHr
11 Aug 2008 23:05
#231501
OMR
I am speaking about this "rake neck" angle on the picture...
What is original, factory angle of this neck on kz900?
  • OldSchoolHr
12 Aug 2008 00:31 - 12 Aug 2008 00:32
#231504
In kawasaki z1 900 service manual I find CASTOR angle is 64 degrees, but I belive that is horizontal angle of steering triangle.
I was looking for angle in the opposite side. Steering neck angle. In fact that is vertical angle of the same triangle and it is 26 degrees.
Am I right with this?
Last edit: 12 Aug 2008 00:32 by OldSchoolHr.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
12 Aug 2008 09:53
#231589
yes,26 degrees is correct.at least on the ones i own.
