Wheels sizes and brake rotors - whats compatible?
- LukeJ
11 Aug 2008 05:06
I have a GPZ750A1 83 model and want to get new rotors and calipers for the front as mine are in really poor condition.
There are 7 allen bolts on the rotors.
I might be able to get to a 85 Gpz900, which only has 6 bolts on the rotors, so these will not fit on the 750's wheel, unless I get the 900's front wheel as well.
Does anyone know if the wheel and tyre sizes are the same on these two different bikes?
Many thanks
Many thanks
- steell
Re: Wheels sizes and brake rotors - whats compatible?
11 Aug 2008 08:30
83-85 GPz750 has a 18" front wheel, 85 GPz900 has a 16" front wheel.
If you want to swap parts around, then I suggest becoming intimately familiar with the parts diagrams at kawasaki.com.
- SPARKY47
- 1980 KZ500 B2
11 Aug 2008 13:04 - 11 Aug 2008 13:04
You're in a minefield
but there's a way out.
I bought some sr650 discs for my 500 'cos they only had a few hundred miles on 'em.
When I went to fit them, the bloody hole in the middle was too small to fit on my front wheel.
Sooooooo....grind off all the [non magnetic rivits] on the FRONT of the old discs and the BACK of the new discs.
Swap the middle bit, use A4 ss [8*2] 6mm bolts.
As long as the "rotor"? [disc] is the same size or bigger, no problem.:woohoo: :woohoo:
1980 KZ500 B2
Last edit: 11 Aug 2008 13:04 by SPARKY47. Reason: I'm old and deranged.
