Lowering Blocks...who has them?
  • Sandy
  • Sandy's Avatar Topic Author
  • Fly High,Tony
10 Aug 2008 13:06
#231180
For the rear shocks...
Anyone know where they can be had?
Anyone here that might be able to make them?
1977 KZ1000 A-1
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Lowering Blocks...who has them?
10 Aug 2008 15:55
#231211
Lowering kit like this, Sandy?
10 Aug 2008 18:34 - 10 Aug 2008 18:36
#231238
On a scale of 1 to 10, say the ride quality with regular shocks and springs is a 10 and struts are a 1.
Imo, lowering blocks come in at a strong 2 when used with the same regular shocks and springs.
Look forward to loose fillings, hemorrhoids, and probably spinal compression fractures. :ohmy:
Last edit: 10 Aug 2008 18:36 by Patton.
  • Sandy
  • Fly High,Tony
10 Aug 2008 19:24
#231252
That kit,John,is for a bike with drum brakes only,but thanks anyway.
I remember now,from aa long time ago,that getting them for a rear disk is almost impossible.
I need to lower the rear a bit...not 2 inches,but some.
I'll have to look at some shorter shocks then.
1977 KZ1000 A-1
  • PLUMMEN
  • PLUMMEN's Avatar
10 Aug 2008 20:01
#231262
have you tried softening up the preload on your shocks?;)
  • Sandy
  • Fly High,Tony
10 Aug 2008 20:09
#231266
Ya,I'll give that a shot and see.I put a set of ZRX shocks on,for our trip up north,and they're even taller than the originals.Not much,but they're taller.
1977 KZ1000 A-1
  • donthekawguy
  • donthekawguy's Avatar
10 Aug 2008 23:29
#231301
Sandy I had a set on my 78. I also had the front lowered 2 inches. The first corner I took at any speed made my kickstand drag. After a new pair of skivies I figured I should slow down around corners. :laugh: The ride was the same as if they weren't on. The shocks still have the same travel.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
