GREASING the SHAFty
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
GREASING the SHAFty
08 Aug 2008 13:38
OK guys mind out of the gutter.
I need to know how much and what kind of grease do I use when putting on the rear rim on a 82 KZ1100 the shaft rim has what looks like a gear that goes into the rim.
- KZQ
- Administrator
Re: GREASING the SHAFty
09 Aug 2008 18:46
Hi WM,
Without my manual, it's at the shop, I use a grease that contains molybdenum disulfide.
But while you're at it have you considered the two sides of the slide joint on the drive shaft? They need the same grease. You will need a long nose circlip plier to get the coupler off but it's not difficult.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
