630 Chain Conversion
- gaillarry
07 Aug 2008 12:07
My 84 GPz750 has a 630 chain with 15 front/38 rear sprockets and its time to change them. Since the 630 chain cost a fortune I'm looking at a 530 conversion. Whats the choices do I have to changeover and have similar gearing?
1977 KZ1000
1985 Gpz750
1985 Gpz750
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
Re: 630 Chain Conversion
07 Aug 2008 12:21
Here's a good resource for information on what you want to do:
www.z1enterprises.com/reference/chain630to530.aspx
They are also a great resource for buying the parts to do it.
West Linn, OR
- Old Man Rock
07 Aug 2008 12:45Since the 630 chain cost a fortune
Due to torque specifications and tesnile strength requirements of the 530 chains, how is the 630 a more expensive chain?
Pricing of the Ek-Chain ZZZ series and the DID chains of the same strength I found there's not that much difference.
In most cases I found the 530 to actually be more expensive.
Granted more colors to choose from but other than that, what am I missing here...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- steell
07 Aug 2008 13:30
Just be aware that you are going to need an offset sprocket for the GPz750, as that's what's on it stock.
Good luck finding one, I found two that were left over from a group buy and bought both of them.
I believe 18/45 in 530 size gives you stock gear ratio, that's what we have on the GPz750 motored 79 KZ650 SR right now. You need at least a 17 tooth front sprocket to keep from eating the swingarm with the chain.
For the 530 conversion on the GPz750 Turbo, after we found out that a 56 tooth rear sprocket was going to cost us $120 we decided to stick with the 630.
And before anyone asks, the Turbo has different primary and transmission ratios than the non Turbo GPz, it runs a 3.07 final drive ratio to make up for it.
- gaillarry
07 Aug 2008 13:36
After reading all the above I'll stick with the stock chain, makes it much easier.
1977 KZ1000
1985 Gpz750
1985 Gpz750
- steell
07 Aug 2008 15:40
gaillarry wrote:
That's what we figured on the 750 Turbo
