Will a KZ1000 ST (79) accept a kickstand lever?
  • KOOL RYDER
  • KOOL RYDER's Avatar Topic Author
  • KZ 650B2 / KZ 1000E
07 Aug 2008 00:34
#230615
There is a spline covered with a rubber cover that says kikstand on it. Can I hook up a kicktand lever?
What lever will work? Is it easy to kick one of these over?
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
Re: Will a KZ1000 ST (79) accept a kickstand lever?
07 Aug 2008 01:02
#230616
Do you mean kick start lever? If so i think a kick start lever from a 900 or a 1000 1972 to 1980 should fit. It is fairly easy to kick start one of the old girls over, and even easier if its in good tune. Hope this helps
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • greychur
  • greychur's Avatar
07 Aug 2008 04:53
#230624
KOOL RIDER,
If you are successful in doing this, please let us know. I would like to put a kickstart on my KZ1000ST too.
Paul
Paul
1978 Z650C2. Marshall 4 into 1. Newtronic ignition. Otherwise stock(ish).
1979 KZ1000ST. Harris 4 into 1. Dyna S.
Hampshire, England
  • wiredgeorge
  • wiredgeorge's Avatar
07 Aug 2008 06:47
#230633
A kicker from most any other bike will work. The original ST came with a kick start that fit under the seat for emergency work - I have never seen one of these. The KZ1000ST isn't any harder to kick over than a Z1 or KZ900.
  • greychur
  • greychur's Avatar
07 Aug 2008 11:24
#230665
I was tempted by a KZ650 kickstart lever on ebay a while back, thinking it might fit the KZ1000ST, so first I took the one off my KZ650 and tried it. It didn't fit. The shaft on the KZ1000ST is bigger than the KZ650.
So maybe it needs to be a kickstart lever from a KZ900 or KZ1000........
Paul
Hampshire, England
  • MFolks
  • MFolks's Avatar
07 Aug 2008 17:38
#230719
Are we talking about a kick start lever for the right side of the bike behind the clutch side cover or a side stand for the left side of the bike?
  • donthekawguy
  • donthekawguy's Avatar
07 Aug 2008 23:49
#230787
I had a kicker for a shafty years ago. I found it under the seat in it's resting place. I guess I should have kept it. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • 6leafclover
  • 6leafclover's Avatar
19 Aug 2008 20:07
#233015
I have a st also but mine came with a kick starter installed and since my electric starter went out i use it everyday.
1979 KZ1000-E1/ST
Madison, IN
  • RonKZ650
  • RonKZ650's Avatar
19 Aug 2008 20:32
#233022
Probably already documented earlier. The ST had the stand bolted to the frame, the Z1R had the exact same stand under the seat. It was like an emergency use only thing, had no swiwel to it, just a kick lever that slid onto the shaft. Any Z1/KZ1000 kickstart setup should fit, or order the right one for $90, but ala Kawasaki tradition NLA most likely.
