Tapered steering head bearings Problem
  • kxhonda
  • kxhonda's Avatar Topic Author
06 Aug 2008 21:34 - 06 Aug 2008 21:35
#230601
I ordered a set of tapered head bearing from Z1E. These here . And I am having a problem with the upper seal. It doesn't sit down far enough to seal anything up. I've made sure that my races and bearings are seated all the way. The bottom bearing seal is good and sits inside the frame. I'm just afraid that a bunch of dirt and grime will get in there and ruin them in no time. I was gonna try to get a pic but batteries were dead in camera. Anyone else have this problem?
1977 Kz650B1 #576th made.
Warsaw, In
Last edit: 06 Aug 2008 21:35 by kxhonda.
  • steell
  • steell's Avatar
Re: Tapered steering head bearings Problem
06 Aug 2008 22:39 - 06 Aug 2008 22:41
#230606
Had the same problem on the 750 twin, there's simply no way to push the bearing race down far enough to fit the seal, so I threw it away.
Figured the dust cap on top will do the job.
Didn't order a top seal when I put the GSX front end on the KZ750E, it would not have fit either.
Last edit: 06 Aug 2008 22:41 by steell.
  • mtkawboy
  • mtkawboy's Avatar
07 Aug 2008 09:44
#230657
I drilled & tapped the neck on mine for a grease fitting and just give it a shot once every 2 weeks . You just have to wipe the excess off but it keeps dirt out...I think
  • kxhonda
07 Aug 2008 18:34
#230733
I think I'm gonna take the top bearing to work and take about 30 thousands off of the top of the inner race with the surface grinder so that the seal sits down closer to the frame. And maybe take some off the the bottom of the race thats pressed into the frame. I really don't like the idea of that bearing being open or squirting grease everywhere.
So I take it this is how everyones AllBalls kit has been on the 650?
Warsaw, In
  • steell
  • steell's Avatar
07 Aug 2008 19:27
#230747
Don't take to much off or the bottom and/or top clamp will rest on the neck.
  • TODDSTER
  • TODDSTER's Avatar
  • Die Hard & Live Free
09 Aug 2008 21:38
#231088
Hi, New member here. Does anyone know if the stem bearing kit from Parts n more does the same as the afore mentioned kit from z1e. for install on kz650 SR? Just curious,
cause I ordered a kit from p.n.m. Just looking for a heads-up!! Great site & lots of good info. on here.
Keep up on the awsome tech. & humor. Thanks for the time &
help in advance.
KOW POW STRONG & luvin it :D :unsure:
KZ 78 650 SR D1a W/78 Quick silver 3/4 stock fairing, new dunlop rubber frnt. & back, new jcw rear shocks, new progressive frt. fork springs & 1 ground-hog to my credit.(ouch)
TODDSTER in N.Western PA
Kawi Strong w/windshield in my face
