Wheel bearing removal.
  • coppertales
  • coppertales's Avatar Topic Author
04 Aug 2008 09:03
#230076
I went to replace my front wheel bearings this past weekend and I could not get the old bearings out of the hub. The circle clips were removed with no problem but the sleeve between the two bearings would not move enough to get anything on the bearings to drive them out. What do you guys do? From the looks of the old bearings, it is the rear bearings whining. That is a bummer because I have to remove the stock exhaust to get the rear wheel off, a PITA. Thanks....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Wheel bearing removal.
04 Aug 2008 09:09
#230081
I purchased a bearing removal tool on eBay (about US$40.00) and it works like a charm...there are several old threads that discussed this tool.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • RonKZ650
  • RonKZ650's Avatar
04 Aug 2008 09:50
#230101
Can't help on the bearings as I've never had to replace a bearing yet, but look for other options than removing the exhaust. They wouldn't make you do that to remove a wheel (hopefully). Some motorcycles you can unhook the shocks and drop the swingarm below the exhaust for wheel removal.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
04 Aug 2008 10:09
#230108
I had the same problem,Chris,but I eventually DID get the collar to loosen up enough to move it to the side enough to get to the edge of the bearing.Get in there with a drift,and see if you can't ge that collar to move to one side.
I just did mine a few weeks ago,before our trip up north.
And yes,bearing puller kits are available at a lot of auto-parts stores.
1977 KZ1000 A-1
  • coppertales
04 Aug 2008 11:28
#230121
Thanks guys........I will hit the auto parts store and look for a puller. chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • eddiem
  • eddiem's Avatar
  • KZR FLAG RELAY CARRIER #63
04 Aug 2008 20:18
#230226
I use a propane torch and warm the hub that makes it a lot easier and when you go back together put the bearings in the freezer and warm the hub up and the bearings will just about fall in place
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
04 Aug 2008 20:51
#230234
As a matter of fact,that's exactly how I do mine,and the last bearing DID drop right into place.
Ya,that's pretty much a must when you're pulling the old bearings out,for sure.And of course,putting new ones back in.
1977 KZ1000 A-1
  • coppertales
05 Aug 2008 08:06
#230289
BTW, Harbor Freight has a blind bearing removal tool kit for 36 bucks. One of their stores is just down the road and on the way home from work.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
05 Aug 2008 08:33
#230292
Got a link?
Just so we can have a look to see if it will work.
1977 KZ1000 A-1
  • coppertales
05 Aug 2008 10:55
#230318
Just google harbor freight then search blind bearing removal tool..............I am going to go look at the kit tomorrow after work....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
