fork oil recommendation
- jon0108
31 Jul 2008 12:29
I want to change the fork oil in my 83 KZ750 LTD Shaft. The manual calls for 5W20 fork Oil. I went to the dealer and he said to use 10W fork oil. Now the springs feel mushy. Should I go with 20W fork oil? What is 5W20 fork oil equivalent to in a strait weight oil?
Re: fork oil recommendation
31 Jul 2008 14:13
Could try ATF for a stiffer ride. Be sure volume is correct per FSM and equal in both sides. Am thinking ATF is roughly equivalent to 20 weight.
Good Luck!
Good Luck!
- bountyhunter
31 Jul 2008 15:21 - 31 Jul 2008 15:27
jon0108 wrote:
I used to know that a long time ago. I do remember I thought my forks were a bit soft and so I mixed some 30W motor oil about 50-50 into the fork oil and they got stiff enough to loosen my teeth.
Fork oil is a different kind of oil, I don't recommend using straight motor oil. They put seal conditioners and detergents in the fork oil as I recall.
One posted opinion:
reference:
www.motocrossactionmag.com/ME2/dirmod.as...40CF833A439ACD16632F
One posted opinion:
Tried 10wt first - nice on pavement, too soft in the woods. Have 20wt in it now - a little harsh on pavement, but great off-road. I'd suggest trying to find some 15wt to start with if I were you. Not all the shops around here had it, but I did find it after stopping a couple places.
reference:
QUESTION FOUR: IS FORK OIL MEASURED BY THE SAE SCALE?
No. Fork oil weights are derived from the industrial standards used for hydraulic applications, called the Saybolt Seconds Universal (SSU). This measurement uses a similar viscometer arrangement as used to determine a cSt value, but grades the oil using a much more sensitive viscosity calibration scale.
Last edit: 31 Jul 2008 15:27 by bountyhunter.
31 Jul 2008 18:56
You should try Bel-Ray 15W Fork Oil. I've been using it for MANY years (changing it every 2 years) with excellent results. Ed
- jon0108
01 Aug 2008 05:30
thanks. I'll go with the 15w. I have belray 10w in it now, i guess its to light.
- coppertales
01 Aug 2008 08:06
I use Belray 20 wt. However, it is hot in Texas and I wiegh 250 lbs...chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- rstnick
01 Aug 2008 08:18
2 or 3 seasoned Kawi riders have told me to use a 30 weight oil in the forks.
I'm still looking for some, but will use the highest number (up to 30) I can find next time.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- bountyhunter
01 Aug 2008 11:45 - 01 Aug 2008 11:47
jon0108 wrote:
Just checked mine and was surprised to see it is PJ-1 20 "medium" fork oil, I thought I was running something lighter. It seems just right for street riding, I only weigh 165.
Last edit: 01 Aug 2008 11:47 by bountyhunter.
- bountyhunter
01 Aug 2008 11:49 - 01 Aug 2008 11:51
rstnick wrote:
30W fork oil here:
www.jpcycles.com/productgroup.aspx?GID=4...56-A628-5B453572125C
Or, the Bel-Ray brand that costs twice as much:
www.jpcycles.com/productgroup.aspx?GID=1...E7-9840-8F53A22012A7
30W fork oil here:
Last edit: 01 Aug 2008 11:51 by bountyhunter.
- jon0108
05 Aug 2008 12:56
I ended up going with the BelRay 20WT. Fork OIl. What a difference. Much,much better than the 10 WT.oil.
