5/8 offset counter shaft sprocket 530 no nose 15t
- 79KZNinja
31 Jul 2008 12:24
Hey guys I know alot of you have been looking for these and PMFR has just made a batch off them. $60 no part number yet. You will have to call them and ask for it.
www.pmfronline.com/counter_shaft_sprockets.htm
Hope this helps
Brett
Hope this helps
Brett
- eel
Re: 5/8 offset counter shaft sprocket 530 no nose 15t
10 Aug 2008 06:07
for what bike(s)????????????
1984 GPz750
2007 ZX6R
53-Racing.com - My Website
My GPz
2007 ZX6R
My GPz
- Old Man Rock
10 Aug 2008 06:20 - 10 Aug 2008 06:26
This discussion & CC sprockets where for KZ900 & 1000 modifications required to wider swing arm conversions.
Go to JT sprockets for matching sprockets for output shaft spline and dimensions... May work for your Ninja...
Same time, a 530 15 tooth is to small in diameter, this is the problem where an 18 tooth is required for chain clearances over the swing arm pivot tube.
Thanks for the link just the same...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 10 Aug 2008 06:26 by Old Man Rock.
