z1 pitted caliper
  • twinkyrider
  • twinkyrider's Avatar Topic Author
z1 pitted caliper
30 Jul 2008 15:04
#229205
My son's 75 z1 has a weepy front caliper (right one of the dual stock set-up). I got a rebuild kit for it but the groove where the o-ring goes is pitted not real bad but enough. We had previously cleaned the caliper but it continued to weep. Should we go ahead and try the rebuild kit alone or can we use a very thin bead of rtv silicone in the groove , install o-ring and piston, let set for a day or two and then install the caliper and bleed? I don't think the brake fluid would interact negatively with the rtv. Has anyone tried this or seen it done or have another idea? Leery of e-bay, been burned a few times. Thanks,Pat
78 kz1000A
Fond du Lac,WI
  • MFolks
  • MFolks's Avatar
Re: z1 pitted caliper
30 Jul 2008 18:53
#229256
I don't believe brake fluid and rtv are compatable. You should look for a good used caliper through the many and various motorcycle salvage areas.
I have some websites to try for new/used parts:
1. www.oldkawman.com
2. www.bikebandit.com
3. www.oldbikebarn.com
4. vintagecyclepart.com
5. www.partsnmore.com
6. www.babbitsonline.com
7. www.z1enterprises.com
8. www.sudco.com
9. www.z-power.co.uk
10. www.cycle-parts.com
11. www.cyclepartsnation.com
12. www.crc2onlinecatalog.com
  • donthekawguy
  • donthekawguy's Avatar
30 Jul 2008 23:45
#229295
What have you done to clean out the grove? I always take a little stainless wheel on a dremel and clean it out that way. Never had a problem after cleaning.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • The Milkman
  • The Milkman's Avatar
31 Jul 2008 05:14
#229311
You don't want to use any adhesive or sealer on that ring. It actually rolls a tiny bit when you apply the brake and helps the piston return when you release it.
As Don said, use a small wire wheel to clean the groove.
Ride safe
  • twinkyrider
31 Jul 2008 06:14
#229320
Advice noted w/ the rtv use, Thanks. Wire wheel, are we talking Dremel or the like? I've got one and a wire wheel, maybe I'll try that, gently. Thanks, Pat
78 kz1000A
Fond du Lac,WI
  • coppertales
  • coppertales's Avatar
31 Jul 2008 07:46
#229344
Calipers are cheap on ebay....never had a problem with the ones I have bought there....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • donthekawguy
01 Aug 2008 04:47
#229512
I use a dremmel. Takes about ten seconds to clean it out. A lot cheaper and faster than buying one on ebay.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • twinkyrider
14 Aug 2008 06:23
#231952
Dremel w/ wire wheel worked great! No leaks! Thanks,Pat
78 kz1000A
Fond du Lac,WI
