brake fuild sight glass
  • ggenovez
  • ggenovez's Avatar Topic Author
09 Feb 2006 21:35
#22868
Hi all,
Just wondering if there is an easy way to remove and clean the sight glass on my 81 kz-1100 A1
Thx
KZ-1100 A1
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: brake fuild sight glass
09 Feb 2006 21:40
#22870
Removing that window without damaging it or the seal around it is near impossible.
I'm not saying it can't be done, but it won't be an easy task.
I think the best way to clean it would be to remove the master cylinder from the bike, cap off the outlet and add some fresh brake fluid, then use a small pipe cleaner or something similar that will be able to reach through the small slit at the back of the window, but soft enough that it won't scratch the glass.
FWIW, I tried removing the glass window on a spare master cylinder I had to clean it, and the glass shattered into about 5 small pieces. :(
Post edited by: RetroRiceRocketRider, at: 2006/02/10 00:41
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • btchalice
  • btchalice's Avatar
10 Feb 2006 04:45
#22885
why not just use brake parts cleaner with the little plastic tube?
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • wiredgeorge
  • wiredgeorge's Avatar
10 Feb 2006 06:33
#22904
If that sight glass is indeed glass and not plastic, use some spray carb cleaner.
