Repacing Master Cylinder with dual calipers
  • civilengr3
  • civilengr3's Avatar Topic Author
28 Jul 2008 08:05
#228675
I have a '77 650C with dual front calipers. The piston in the master cylinder is sticking, so I need to replace it. I have a friend who has a M/C off a Harley with dual calipers. Will this work, is there anything I need to look out for, like amount of travel or anything? I would think it'd be okay since all a m/c is doing is compressing fluid. Anyone have any experience with compatibility? The other plus is being able to use Dot5 fluid...
1977 KZ650C
East TN
  • JMKZHI
  • JMKZHI's Avatar
Re: .
28 Jul 2008 08:16 - 04 Dec 2008 07:14
#228678
del
Last edit: 04 Dec 2008 07:14 by JMKZHI.
  • cmmman
  • cmmman's Avatar
Re: Repacing Master Cylinder with dual calipers
28 Jul 2008 08:17
#228679
The harley may have 1 inch handle bars so the mount will be larger. Probably still work but you will have to adapt to your 7/8" bars.
1977 KZ650B, modified.
