Front Brake Extreme Squeel
  • Kawifan
  • Kawifan's Avatar Topic Author
27 Jul 2008 05:02
#228489
I can't figure this one out. The front brake on my '78 KZ1000 A2A squeels really loudly when engaged. The pads are ok. the disc doesn't feel gouged or scored. It's not a light squeel...it's attention getting. Can't be normal!?
1978 KZ1000 A2A
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Front Brake Extreme Squeel
27 Jul 2008 05:58
#228491
A squeel is actually a high speed vibration, big trick on cars with amazing results is to remove pads and put a thin layer of high temp grease or synthetic disc brake lube (great stuff for everything) on the back of the pads. Also make sure all caliper sliders are clean and lubed. ;)
  • fixer5000
  • fixer5000's Avatar
27 Jul 2008 09:17
#228520
this is what worked for me
1978 kz650b pretty much stock
massachusetts
  • bountyhunter
  • bountyhunter's Avatar
27 Jul 2008 12:48
#228540
Way back when, Mercedes cars used to squeal and they would take the pads off and drill several small holes in them and insert carbon rods like hard graphite. The slight lubricating effect meant the squealing stopped.
The back brake on mine has always squealed, REALLY bad when it's cold then gets quiet after it gets warm. I did all the fixes: putting the blue-goo on the back of the pad, it worked.... for a couple of weeks. I drilled my pads and poured a bit of dry graphite in the holes... wprked until the graphite got used up.
Eventually, I just bought a helmet with better sound insulation.:laugh:
