newbie here
- ltdluke80
newbie here
09 Feb 2006 19:53
great site. tried the thread thing and didnt have any luck. got an 80 750 ltd(h) and noticed the center stand stop is jerked up and real close to the chain. found a thread that mentioned the stop doubling as a tensioner. does this have a duel purpose? if so is the tensioner needed? appreciate the help!
thanks,
luke
thanks,
luke
- rstnick
Re: newbie here
09 Feb 2006 20:00
Welcome Luke.
I doubt your centre stand stop would double as your drive chain tensioner. I have never heard of a tensioner on a KZ's drive chain. The drive chain must be adjusted to give the right amount of slack, at it's tightest point when rotating the wheel, of approx 3/4 of an inch.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- ltdluke80
Re: newbie here
09 Feb 2006 20:42
sorry if i cone across as an idiot. i understand the mechanics of the drive but i read someone elses post and thought i was missing something. having said that my stop appears to be misshapen and now rubs the chain in a manner which doesn't look safe>
- ltdluke80
- wiredgeorge
Re: newbie here
10 Feb 2006 06:37
Well... like the ol' country song says,
"You can read a lot of different stories, in a lot of different books... but even then you won't really know"
I suspect your chain should be guided by your center stand. The two chain adjusters in the rear should tension the chain so that it doesn't drag on the stand. There is a lot of advice on this site... some is on the mark and some is frankly, not on the mark.
You mentioned something about a broken bolt but there was no reference. What is the problem?
- rstnick
Re: newbie here
10 Feb 2006 06:41
My center stand stops will sometimes move into the wrong position and allow the center stand to come up too high. I have aftermarket stops that came with my exhaust. I know this happens periodically, so I watch for it and move the stops back into place. I'm thinking of removing my center stand to save weight and for looks, and just put it on when I need to do service.
You mention guide. Your chain should not rub against anything. If it does, you may have too much slack in it.
There is the chain guard, which keeps your pants/shoe laces or whatever from getting tangled in the chain, as well as keeps some chain lube from flinging all over the place. My chain used to rub on my chain guard sometimes, but my guard was plastic. If your guard is metal, then you definatly don't want it to rub against it.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- ltdluke80
Re: newbie here
11 Feb 2006 14:12
no broken bolt, the center stand stop is all bent up, anyone have one for 80 750 ltd h?
Post edited by: ltdluke80, at: 2006/02/11 17:14
